How can i tell if the case i have is the one needed for the
rockhopper? its got a plug at the front and wires,is that the one
or do they all have that?
Al
SJ410 transfer case
suzookyman
SJ410 transfer case
Re: SJ410 transfer case
suzookyman wrote:How can i tell if the case i have is the one needed for the
Al
Should be the one. The earlier ones had no switchs (plugs/wires). Only the 1984 models had them (last year they were produced) Failing that pull it apart and count the teeth.
You have the web links to show what needs to be done?
