Winch for SWB pajero
Hey guys, just wondering ....new to winches etc and never owned one before. Looking at buying one to fit to my swb pajero and wondering if an 8000lb is the way to go ? Is that sufficient for the weight of my truck or is bigger better? Thinking about the Runva unit
any suggestions would be good , cheers
Re: Winch for SWB pajero
this is one time where Bigger IS better
(my wife is rather impressed with my winch btw
anyway ... *cough* Ive got a 9000lb Warn on my 88 LWB she weighs in at a hefty 2400kg loaded up, sometime ive been stuck deep enough to have to use a snatch block to get me out, Id go for at least a 9000lb winch .. maybe even a 9500-10000lb one if the budget allows,
usual rule of thumb is pulling power 2.5 times the (fully loaded) weight of your truck
Just remember that the winch rated pulling power is ONLY on the very last wind of the wire (so my 9000lb winch with 35-38m of plasma rope is pob only pulling a tad over 5000lb fully cabled up. .. when your stuck chassis deep in lovely northland mud .. 5000lb dosnt help much
BTW From a winch review i read a while ago Runva winches output was slighty under their rated pull .. not a lot but something to think about when buying a lower rated winch ... HOWEVER I used to have a Runva winch on my old Fez and Boy could she pull, Noisy and slow but never let me down
Oh and my experience with Pajero's and winches .... Upgrade your alternator to at least a 95 Amp one and run at least one 850 AH battery or better yet 2 battery setup .. the Runva's are good winches but like any winch they have a horrendous amp draw (my Warn draws 480 Amps in a short pull!!! ) .. I have a 1000AH truck in mine battery and try and keep my winch pulls as short as possible
Thanks heaps for the useful information , really good to know
Espeacially the alternator upgrade, will prob do the two battery setup, and was thinking of going for the 9500lb runva.
Cheers againm and good to hear of another old school pajero arond!
Your V6 Pajero should have a higher rated alternator
