lada niva
Denz
lada niva
Post by Denz »
Hi there anyone know where i can get parts for a lada niva 1600 or more specifically a timing chain adjuster.
Mongoose
Post by Mongoose »
It's in Christchurch unfortunately but I got plenty of bits for my Niva, including a timing chain tensioner, from Murray Costello cars in Addington. 0-3-338 9161
They used to be a Lada dealer and still have a good stock of Lada parts. There is a place in Napier too I think called Gee Motors.
Hope that helps.
Cheers.
Greg
[O]=TOYOTA=[O]
Denz
Post by Denz »
okay thanks for that i will give them a call tomorrow.How is the easyest way to fit it does it clip in down the bottom or something?
Mongoose
Post by Mongoose »
It's a bit of a pain to get to actually, you need to take out the front panel and the radiator to get the cover off to get it in. I have a workshop manual still so if you like I can scan the relevant pages and email them to you. Let me know.
[O]=TOYOTA=[O]
Denz
Post by Denz »
yeah i thought all that would have to come out but was hopping otherwise. That would be great if you could Denz7@hotmail.com thanks for all the help
Mongoose
Post by Mongoose »
Are you sure the tensioner needs replaced? My chain was smacking around badly when I got the Niva but just needed the tensioner adjusted and it was sweet.
Otherwise I'll scan those pages for you tomorrow and email them off.
Denz
Post by Denz »
well i got the car for free because the previous owner was told the con rod was snapped but it turns over etc and valves move so i think it is out of timing and i found part of the adjuster it was snapped in half and the chain is really loose but i cant adjust it. I found this http://www.wnc.asn.au/index.php?option= ... &Itemid=42 and im missing part 38 (well i found half of it) so that is what i think i need.
Mongoose
Post by Mongoose »
k no worries, sounds like you do need the tensioner. I'll scan that stuff and send it off, from memory the pictures are much better than that one you found.
Denz
Post by Denz »
okay that would be great thanks alot for your help
niblik
Post by niblik »
:shock: thats really funny as a cobber of mine has the same problem.. the chain slaps more than a dominatrix's annual meeting! :lol:
Mongoose
Post by Mongoose »
Yeah mine had been slowly wearing a hole in the chain cover, still went fine though. Nothing seems to stop those Niva's driving home no matter how much you thrash them. Still got a soft spot for Nivas, big grins, cheap to buy and surprisingly capable.
Cloggy_NZ
Texas Chainsaw
Post by Cloggy_NZ »
niblik wrote::shock: thats really funny as a cobber of mine has the same problem.. the chain slaps more than a dominatrix's annual meeting! :lol:
Yes a very common problem with any Lada. An aussie engineer made a modified version with a sprocket rather than the wear pad to alleviate this problem. Not sure if they are still available but if they are, I am sure there will be a link still somewhere on that WNC website.
I am also a ex-Niva owner and fully agree with Mongoose, Niva's rock :salut:
I have a very large softspot for them still.
niblik
Post by niblik »
as far as value for buck goes, the dollars spent on a std lada go a long way.. :wink:
Denz
Post by Denz »
finally got the internet working again so all the lada fans are coming out then hay great stuff. Thanks mongoose for the number ive ordered the part so will have it running again soon.
Mongoose
Post by Mongoose »
Excellent stuff, aye we've been snowed in with no power or phone for a couple of days but back up and running now so I'll be in work tomorrow. I'll do the pages from the workshop manual and send em off soon.
Glad they had the part.
Cheers.
Greg
Mongoose
Post by Mongoose »
Hey Denz,
Email sent finally with those pages. Hope it's ok.
I could probably have the whole manual converted to pdf if you want but there would be a charge I think.
[O]=TOYOTA=[O]
Mongoose
Post by Mongoose »
Asked round at work and I can get the whole manual scanned to pdf for $5 so I'm happy to do that for any closet Lada fans on ORE if people are keen.
If there was some way to add it into an album so it could be downloaded that'd be cool too but not sure if that's possible......
Anybody keen?
[O]=TOYOTA=[O]
