cruiser diff vs safari diff
zookfest
Post by zookfest »
80 series front diff and cvs vs safari/patrol front diff and cvs
whitch of the 2 is the stronger more reliable
looking at getting 1 of these and want to know whitch is best
Death to the competition
rangimotors
Re: cruiser diff vs safari diff
Post by rangimotors »
dean you know how john showed us his 80 cv the other day? I think that was the bigger of the two, I never knew it but after reading a thread on here the other day it would seem there are 2 sizes of 80 cv's. I guess you also need to look into sixe of the diff head and clearance, would you prefer to go for the bigger stronger diff and loose some clearance (even though your running 38's) or go the smaller gear and have better clearance.
You haven't broken anything yet so why not just upgrade when you need to? Obviously you need to change ratios because of the 4.1's and big tyres. Im not a cruiser guy but is it right that you can go to a better ratio but using gears from a toyota dyna? could be a cheap option..
cruzerboy
Post by cruzerboy »
id say safari would be a shit load stronger uve seen how rory drives his and has only blowen hubs never a cv but they are a lot bigger in the head than a 80 diff but with 38s u can aford to lose a bit of diff clearance. a safari diff wouldnt be any difrent clearcnce wise to what uve got now.ether way you would probley need to coil it like mine or the leafsprings will endup on top of the diff head and itd be higher than it is now lol
MNC
Post by MNC »
rangimotors wrote:... Im not a cruiser guy but is it right that you can go to a better ratio but using gears from a toyota dyna? could be a cheap option..
Can anyone confirm this - I'd be interested to know what ratio the Dyna diffs are (have heard the same thing before but cant confirm)
rangimotors
i think rich's (muddyplummer) new truck has them, he got it from kiwimidi or something like that so one of those two might be of more help, or maybe we'll just pull one out of richs diffs out when he's not looking, im sure you could use his arbs as well dean :D
i cant remember wher i read about the dyna diffs so dont take my work from it, ill stick to my hilux diffs.
MNC
Post by MNC »
rangimotors wrote:i think rich's (muddyplummer) new truck has them, he got it from kiwimidi or something like that so one of those two might be of more help, or maybe we'll just pull one out of richs diffs out when he's not looking, im sure you could use his arbs as well dean :D
Right, so the Dyna diffs fit the 70 series and 80 series diffs? Think they were 5.29s?
turoa
Pyro Junior
Post by turoa »
apparently the dynas have a 6.37 ratio or something silly.
http://www.outerlimits4x4.com/ftopic149568-0-asc-30.php
There is a bit of a debate on 80 vs gq front ends. 80's have a decent size cv but a weaker front diff head and gq's have much weaker cv's (not much larger than hilux) and much stroger diffs. Both are high pinion.
If you want the best of both worlds track down a GU front end. Massive cv's with a strong head.
Or you could go custom and use a nissan diff head and 80 outers. Is quite common is oz
zookfest
Post by zookfest »
yea mate the way rory drives makes me want a safari front,i havnt broke anything yet coz im driving it like a nana with stock 70 cvs :lol: ,ive got an 80 rear lined up so ill do that first
albundy
Rolly Polly
Post by albundy »
It is a well known fact back in Oz and well documented in their 4wd magizines that nissans have stronger running gear then toyotas. Why do you think there is a run on at the moment of guys fitting nissan running gear under their trucks. saying that I have still managed to break a nissan CV.
Al
rokhound
Post by rokhound »
Why not just put 30 spline longfileds in what you have? Then you have stringer cv's than either of your other options. Doesn't sort the diff head issue though. But having said that, I don't think it is a common thing to be blowing 9" cruiser diffs apart (70's are 9" aren't they?)
mudzilla
Post by mudzilla »
MNC, I owned and built most of that Midi ( ex KiwiMidi Now Muddyplumber) .. It has 5.29 Dyna Gears , ARB's and longfields.
smurf182
Post by smurf182 »
rokhound wrote:Why not just put 30 spline longfileds in what you have? Then you have stringer cv's than either of your other options. Doesn't sort the diff head issue though. But having said that, I don't think it is a common thing to be blowing 9" cruiser diffs apart (70's are 9" aren't they?)
They have a 9.5" crown wheel.
mudzilla wrote: It has 5.29 Dyna Gears , ARB's and longfields.
sounds faaaarking strong to me :shock: :shock: :shock: :shock: :shock:
no need for this thread :roll: :mrgreen: :mrgreen: :mrgreen:
zookfest
Post by zookfest »
its a width thing im also after,the diffs have been sweet but i dont really drive it with my foot up it alot,ive been quite cautious with it with the big rubber but i want to be able to feed it fat if i need it to without breaking things
ive noticed a huge drop in tippyness with the roof and rear doors gone so its getting there but just want to go a bit further and widen the front since ive got the back lined up
zookfest wrote:its a width thing im also after,the diffs have been sweet but i dont really drive it with my foot up it alot,ive been quite cautious with it with the big rubber but i want to be able to feed it fat if i need it to without breaking things
if you are planning on making the front wider than the back, I don't recommend it. Your road handling will be absolute shite if you do that.
keep same diffs front and rear, so either go for spacers on wot u got, or 80 diffs to make it wider, or nissan diffs to make it really wide
MNC
Post by MNC »
Thats in a different truck though Skid.
I agree, would love to have a diff set-up like that - big$$$$
Go the spacers to gain width as suggested - easiest by a county mile.
MNC
Post by MNC »
PS, and give me your 80 series rear end :wink:
mudzilla wrote:MNC, I owned and built most of that Midi ( ex KiwiMidi Now Muddyplumber) .. It has 5.29 Dyna Gears , ARB's and longfields.
That was a nice bit of kit. Was watching it on trademe but need to upgrade the wifes car first. Thinking of getting her a VX Cruiser :D - Anyone let me know if you hear of a good deal out there.
I'd like a similar set up to that Midi with 80 series diffs under a FJ40 - Bens fault... putting stupid ideas in my head :lol:
mudzilla
Post by mudzilla »
They are 60' diff's,, Spring over in that Midi... And nothing wrong with Ben's ideas, you just need money and knowhow.
You can get about 150mm extra track with a centre flip in your rims, $30 plus GST each when I had mine done
muddyplumber
Spring Free
Post by muddyplumber »
yea i brought the midi ex kiwimidis truck, from what iv been told they are out of a toyota dyna 5.29s with longfields, goes bloody well, runs the 36s iv put on it with ease :D , may do turned rims aswell.have 1" spaces coming shortly.
cruzerboy
Post by cruzerboy »
rorys got that leaf sprung GQ front end at his place shore you could make that fit under it :D
zookfest
Post by zookfest »
ya just gota get that 13bt running like mine now rich :D yep pretty keen on that saf diff of rorys.mite have to measure it again
got 50ml spacers on the ute already
zookfest
Post by zookfest »
muddyplumber
Spring Free
i could never catch you now yourv turned it into a ute, iv got doors n a canopy n yours is running like 25lb boost :lol: :lol:
cruzerboy
Post by cruzerboy »
you'll catch him when it blows up :lol: :lol:
zookfest
Post by zookfest »
you know how much these motors take alex they run upside down then drive home :lol: :lol:
cruzerboy
Post by cruzerboy »
lol yea true forgot about that i cant say shit mines running bwt 15psi and the pumps tweked a bit lol loves the revs :D
wopass
Post by wopass »
skid wrote: 80 diffs to make it wider, or nissan diffs to make it really wide
80 series cruiser is wider than GQ by a little bit :wink:
wopass
Post by wopass »
ohh the dyna has lower gears and will fit in the 80 rear end but not the front so you would have to get a gear set in from the states for the front or go for a 4.3 diff from a petrol dyna in the rear and a prado hi pin 4.3 for the front... no i havent researched it... ok maybe i have but just cant afford it :lol:
Jafa
Post by Jafa »
We can do 5.29 Hi pinion gear sets for $470 or so NZD
021 273 9942
jafa@inspire.net.nz
Return to “Tool Shed”
