Adjustable Panhards
brakes-shocks-lockers-etc
flyingbrick
Adjustable Panhards
Post by flyingbrick »
Does anyone have anything to look out for when purchasing a set of adjustable panhards. Are some brands cheaper/stronger/come with bushes/something else im forgetting that others dont?
I'm needing a pair for my GQ.
cheers.
wopass
Re: Adjustable Panhards
Post by wopass »
i got TOUGH DOGS as they have a good reputation for being made well...and they are :wink:
just ordered a front one off superior engineering one the other day
flyingbrick
thanks for that. The TD ones at 320nzd (excluding postage) should be a bit cheaper than the EFS ones even. :mrgreen:
Whats the bar cost ya from superior, Coxsy?
$250 AU + shipping
flyingbrick
thats NZD? :shock:
no $AU
wopass
Post by wopass »
pretty sure i got mine for bout 300 for both from a guy on TM... see if i can dig up his details...
flyingbrick
:shock: :shock: :shock: :shock:
I'm betting if he was selling for 300/pair he could clear out his warehouse in a few days on ORE.
-NAthan
tgaguy1
Post by tgaguy1 »
flyingbrick wrote::shock: :shock: :shock: :shock:
-NAthan
At $300 a pair, I would buy a set just to have as spares.
1nzsafari
Post by 1nzsafari »
what would you pay for 2nd hand adjustable panhards (front & rear) that need new brushes?? cheers
tgaguy1
Post by tgaguy1 »
1nzsafari wrote:what would you pay for 2nd hand adjustable panhards (front & rear) that need new brushes?? cheers
Have you got some there?
Maybe JAFA can make some :D
shroom
Post by shroom »
am looking at these to buy for the rear after the 2" lift was done. They need bushes, but for $160 a pair, I dont see how you can go wrong.
http://www.trademe.co.nz/Browse/Listing.aspx?id=238040912
What are peoples thoughts on this guys stuff?
DaveM
Post by DaveM »
I run his trailing arms, no problems with them
darinz
Post by darinz »
shroom wrote:am looking at these to buy for the rear after the 2" lift was done. They need bushes, but for $160 a pair, I dont see how you can go wrong.
And why do you need them? At 2" you don't need to change anything! I ran a 3" lift with all standard arms, no castor correction and standard panhards. And in that form it did a fair bit of high speed open road driving with no major handling problems. The joy of standard panhard rods (in particular) is they bend before other things break. Noting like having a controlled weak point that ultimately saves you money!
shroom
Post by shroom »
Ive got a horrible vibration in my driveline - everyone I have spoken to has stated you need longer panhard rods to correct the angle at which the rear diff points back to the gearbox. The extra 2" puts extra stress on the uni joints on the driveshaft.
haydgq
Post by haydgq »
Sounds like you need adjustable top control arms or bottom trailing arms to adjust the pinion angle, Its easier using longer top arms to get the casing rolling back bringing the pinion angle up towards the rear output on your transfer case.
The panhard rod only stops the diff casing moving sideways to much.
haydgq
Post by haydgq »
And with a 2" lift it shouldn't cause to many vibrations but gear box packers can be used to lower the trans/transfer case to bring the angles back to standard but remember this will cause the g/box and crossmember to hang down lower at the same time. :shock:
albundy
Rolly Polly
Post by albundy »
Have you tried gearbox spacers?
shroom
Post by shroom »
haydgq wrote:Sounds like you need adjustable top control arms or bottom trailing arms to adjust the pinion angle, Its easier using longer top arms to get the casing rolling back bringing the pinion angle up towards the rear output on your transfer case.
Apologies, I think ive used the wrong name here... :lol:
Yes, I think what I am referring to is the upper or lower control arms.
I think that auction was for the top arms, 8 or 16mm longer (assuming for a 2 or 4" lift)?
shroom
Post by shroom »
albundy wrote:Have you tried gearbox spacers?
I looked at them, not tried them yet. I have read a few things that said lowering the gearbox is not really a good thing
haydgq
Post by haydgq »
My Safari had a OME autokraft 2" lift and they fitted the gearbox spacers and it was perfect with no shudders at all so i would recommend trying them, Or just make some to fit i think the ones mine had were about 10mm but i cant recall 100%,
Maybe ring Autokraft and see how thick they are or ask Badnuz on here as he works there.
Also you might have 2" springs for a lwb truck hence they might be a little higher than other 2" kits for the swb gq/gu wagons.
DaveM
Post by DaveM »
You are meant to use longer lowers, shorter upper, or a combination of both.
If you are spending money on arms, I'd go for longer/stronger lowers as the lower arms are a weak spot anyway.
shroom
Post by shroom »
DaveM wrote:You are meant to use longer lowers, shorter upper, or a combination of both.
well that confirms it then. the auction for for longer/stronger lowers. thanks all!
