SR20 Engine mount(s) needed
For all Nissan related topics
downunderxj
Post by downunderxj »
My wifes '95 Nissan Bluebird SSS failed it's last warrant due to the top engine mount rubber being completely stuffed. So I am looking for a new replacement engine mount. Not sure of the condition of any other mounts, it was only the top one that failed the WOF.
Anybody know the best (i.e. cheapest) source of quality replacement items
Local Nissan Parts Store
Ripco
Supercheap
etc
Thanks
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
Re: SR20 Engine mount(s) needed
There must be one of those around the corner at pick-a-part Ian :mrgreen:
downunderxj
Good thinking - that's Saturday morning taken care of
T-Boon
Post by T-Boon »
yeah, there`s always heaps up here at pickapart(s), and you can pull em off and inspect, find the best one and your golden :D
To Boon or not to Boon.
Bolo
2XL
Post by Bolo »
My Partners car needed the same thing , and yep Pick a Part to the rescue :mrgreen:
Bolo wrote:My Partners car needed the same thing , and yep Pick a Part to the rescue :mrgreen:
I bet her car was a "95 Nissan Bluebird SSS" and you got the only engine mount for one of those things up there :lol: :lol: :lol: :oops:
4x4newb
Post by 4x4newb »
Last time i went to PAP for an engine mount, they were all cracked! Ended up having to get one from the manufacturer.
Addicted to Mud. :twisted:
flyingbrick
Post by flyingbrick »
Is it one of the circular engine mounts? If so- its very easy to repair using a tube of urethane.
Bolo
2XL
Post by Bolo »
Na Mate a primera , and there was heeps of thoses mounts up there :wink:
Dodgysam
Post by Dodgysam »
Same engine mount.
And i bet all these stuffed engine mounts are the front engine mount...am i right?
The Primera and the Bluebird are essentially the same car with different sheet metal so most of the mechannical parts should swap straight over.
I had a Primera and then a gtir Pulsar...dead easy engines to work on...just dont try working on one of their 4wd gearboxes...cos thats a beeyotch!
Patience is not a virtue. Its a weakness!!!
downunderxj
yep, got one out of a '91 Primera with the same SR20 engine. while it is not perfect it is in a lot better condition than my wife's one. Her's is a '92, not a '95 as I first listed.
The shape of the metal housing is very slightly different but I am pretty sure it will go
The rubber does have a small split in it - is there anything I can do to fill that split so it is not obvious to the wof man, and helps glue it together.
Thanks
flyingbrick
yes.
either Urethane (sold as product window weld) or just that black silastic silicone in the green/white packaging- used for sealing windows also. silastic stuff available from Repco. Unsure about Urethane.
downunderxj
thanks for that flyingbrick - will make a trip to Repco tomorrow and see if I can track it down.
Cheers for the help :D
downunderxj
Success at last
The engine mount that I sourced from Pick a Part was from a '91 Primera and while they looked the same initially there was a slight difference in the hole placement.
Got a matching one from a Nissan Wrecker on Hutt Park Road on Saturday, and one hour later had the warrant all sorted. This one cost me $45. Not too bad.
Thanks for all your input
Ian
Return to “Nissan”
