safari odomoter and trip meter
For all Nissan related topics
Safari Swb
Post by Safari Swb »
the odomoter and trip meter died in my safari this afternoon, yet the speedo still works. anyone else hav this problem?
albundy
Rolly Polly
Re: safari odomoter and trip meter
Post by albundy »
Could be one of the wires out of the back. This is a common method used by some to beat RUC, cut the wire!
albundy
Rolly Polly
Post by albundy »
could also be the little gears that turn the numbers over, have you tried pushing the restset button several times, could be stuck.
Safari Swb
yep just pressed it and it works again :oops: :oops:
DaveM
Post by DaveM »
Safari Swb wrote:yep just pressed it and it works again :oops: :oops:
I woulda left it for a bit longer :wink:
Safari Swb
yer i know. i was guttered i pressed it but my curiosity got the best of me haha.. hopefully it jams again
sig
Jeep Jeep
Post by sig »
easy fix .on the back of patrol speedos is an electrical plug with six little wires that connects speedo to odometer .if plug "falls" out speedo works but odometer doesn,t :oops:
Safari Swb
haha sweet. wont be doing that for a while as the engine in it died this arvo :lol: :lol:
3VILC
Post by 3VILC »
Mine also does this 'jamming' trick sometimes when resetting the trip counter. Do need to accidentally knock that plug out tho ;)
flyingbrick
Post by flyingbrick »
Safari Swb wrote:haha sweet. wont be doing that for a while as the engine in it died this arvo :lol: :lol:
How can you remain happy considering this? lol.
Safari Swb
im actually pissed off. aparntly these engines are prone to it tho(2.8's not 4.2's). just bought a new set of mud terrains and didnt even get to try them out :evil: :evil:
gary_in_nz
Post by gary_in_nz »
you had better look at putting an rb30det in then hehehe or maybe go for a v8??
muskie
Post by muskie »
my odometer does the same, but now its very slow to clock over the numbers 20 kms and my odo actually clocks over about 3 kms. needs a new one now
Safari Swb
I got the dash apart in my safari atm so i thought i would fix a few little things that annoy me while its apart
does anyone know which color wire in the speedo wiring loom i need to cut in order to stop the speedo from clocking over??
and is there anyway i can stop the odomoter itself without stopping the speedo??
disclaimer: odomoter will only be disconnected for when I go offroad
sig
Jeep Jeep
Post by sig »
if you look at the back of the speedo there is a small plug with 6 tiny wires in it .if you follow them back to the circuit board 2 of them end up together (possably black and green!)these are the neg for each stage of the odometer motor .these can be cut and a switch put in "for offroad use" :lol: and then you are done .note : be careful when you strip the wires back they will pull out of the motor very easy :( then its new odo motor time ,know this from experience)hope this helps cheers sig
Safari Swb
cheers for that!!!
GQTROL
Post by GQTROL »
Safari Swb wrote:I got the dash apart in my safari atm so i thought i would fix a few little things that annoy me while its apart
Put a switch on the black wire.
Return to “Nissan”
