The initial idea was to add a spreader across the factory front bars (that go from windscreen to B hoop) and from the centre of that spreader, adding a T back to the B hoop. On the back theres to be a spreader at the top corner of the side hoops, with two bars returning from the top corner of the side hoops back to the centre of the B hoop, triangulating the rear.
Seeing as how the freebie didnt have the stock front bars, and rather than using my original ones (keeping the original cage in its original state) had to make some up, from there the creative juices were flowing and decided to pop a bar down to into the firewall also, a-la the Rokhard4x4 clamp on version of cage. So the new bars will tie back into the windscreen, as per factory, as well as into the firewall. A bar will also probably be added across the top of the dash also.
And before anyone starts bleating, I'm just tacking the thing together for the sake of ensuring everything fits, a suitably ticketed person is going to be doing the required welding, and the cage will be certed.... eventually.
Heres some progress pics......
Once the original cage was off.....
The replacement one goes on.....
And the start of the new barwork....
