Replacement bulbs... narva +50's, Bluepower or other??
As the title suggests, looking at replacing bulb, because, like other things on the Jeeps, the stock ones are crap.
Was referred to the +50's but after looking at some reviews, it seems theyre not what theyre cracked up to be. However the Narva "bluepower" seem to be flavour of the month at the moment, but at $60.00 a pair (appco), theyd wanna be worth it.
Does anyone have any insight to these, or alternatives? Seems Super Cheap do some, that are problematic.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Re: Replacement bulbs... narva +50's, Bluepower or other??
I ran the +50's in my diesel zuk and my old LJ71, the problem I found with the LJ was all the mud getting into the headlight, was looking at putting a sealed beam lights into that before I sold it and adding additional spotties/driving lights. found the +50's to be better than stock...
Thats the info i was after.... how much better though? Marginally, or heaps?Jerry wrote: found the +50's to be better than stock...
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
depended on the reflector behind the bulb, the Zuk had this fancy shiny pattern which make it really bright, better than the standard shiny surface on the old playdoh...it was better but the zuk was betterer if you follow my drift....
- skid
- Tyre Man
XJ ya dirty ol fawker
I'm gonna hijack ya post
has anyone ever changed the bulbs in thier 80 series landcruiser
mine are absolute shite and I wanna be able to see better at night
skid wrote:mine are absolute shite and I wanna be able to see better at night
Opening your eyes helps.... girly swat.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- skid
- Tyre Man
xj wrote:skid wrote:mine are absolute shite and I wanna be able to see better at night
yes grasshopper
I had some +50 or simular, made fck all difference. Complete waste of fckin $$
Benjamin Franklin
Benjamin Franklin
I have Hella +90s in the 80, they pretty good, but over $60 a pair....
we also sell a "chinese" bulb, 80/85w but they are the equivalent of 130/100w, and they are about $20 each.... i used the 24V version in my 70, VAST improvement!!!!!!!!!!!
or IPFs
or IPFs
- Andrew1706
I don't know how jeeps wiring is, but if you're going to upgrade to bigger bulbs then upgrade the wiring too.
I'm going to do a complete rebuild of my lighting system in my 80 Series cruiser (only one headlight goes at the moment) to incorporate 100/90w and 130w beams and semi sealed lamps too with my own heavy wiring.
Also a regular clean of the lenses helps
Andrew1706 wrote:I don't know how jeeps wiring is, but if you're going to upgrade to bigger bulbs then upgrade the wiring too.
Its not upgrading to a bigger bulb. Theyre still an H4 60/55w.
Yeah, one lamp wore a heap of nice muddy water a while back, so the whole thing needs to be taaken apart and cleaned.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
badnuz wrote:I have Hella +90s in the 80, they pretty good, but over $60 a pair....
Do they come in H4 60/55w?
(I hear dixie has been loitering around your shop of late, watch him hey, he's sketchy!)
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
- Fourbyfour
badnuz where did you get the +90's from I have been looking here in Auckland but no luck so far.
+50'S are available in H4 and are 60/55 Watt, the +90's are also a 60/55 bulb so suitalble with vehicles such as my Surf which has polycarbonate headlights and I believe are available in H4.
Getting back to the original post the +50's will probably extend your range by another 10 to 15 metres over standard lights but will also give you a little more light out to the sides. +90'S or an HID kit would give you evn more light.
Get yourself a multimeter and do a check of the voltage at your battery with engine running at about 1100 rpm and also do a check of the voltage at the lights if more than 1 volt difference you might also want to consider relays to reduce the voltage drop at the lights.
DO NOT GET THE BLUE BULBS from SUPERCHEAP! I have a set in my DD Surf, they are miles worse than stock sealed beams
They are almost like a fog lamp, not bad up close, but no depth to them whatsoever..... mind you they were only about $15 each
021 273 9942
jafa@inspire.net.nz
021 273 9942
jafa@inspire.net.nz
Be careful with higher wattage bulbs. The WOF man may not like them and polycarb lens and reflectors dont. The HID ones are good but illegal unless the same headlight unit (reflector lens etc) on a up spec model had them factory. Crazy rules especially with the HID ones but thats how they sit at the moment.
As for the original question if you have crap on the reflector no bulb will make much difference
- Fourbyfour
meatc wrote:Be careful with higher wattage bulbs. The WOF man may not like them and polycarb lens and reflectors dont. The HID ones are good but illegal unless the same headlight unit (reflector lens etc) on a up spec model had them factory. Crazy rules especially with the HID ones but thats how they sit at the moment.
I think the rules were copied from Aussie as they have the same regulations.
If your vehicle has a single headlight (ie hi and low beam combined) HID is not allowed
If your vehicle has separate hi and low beams you can put HID in the high beam but not in the low beam
You are allowed HID in spotlights
advantage of HID is that a 35 watt Hid bulb produces the same amount of light as a 120 watt halogen with a lot less heat.
disadvantage is the kits are bloody pricey.
I am putting HID driving lights on the Surf and will just use +90's to brighten my low beam.
I have already checked voltage at battery and compared it with voltage at the headlights, there was only .3 of a volt difference.
+90's apparently do not create any more heat than a standard 60/55 watt bulb
narva arctic blue is what i run in my bus, best bang for buck
- skid
- Tyre Man
wopass wrote:narva arctic blue is what i run in my bus, best bang for buck
in the tow bus Wop ???
and if so, on the outside lights or the stooopid inside yellow ones ???
skid wrote:wopass wrote:narva arctic blue is what i run in my bus, best bang for buck
yea tow bus, the headlights yes, not the fog lights. i put the plus 50's in the spottys but i think the arctic blues give a better light. i like the fog lights on my bus, probably cos living in the waikato i get the benifit from having fog nearly every morning
remember here people that you wont get any more "distance" out of your lights but you can make what yuou have got better. i find the arctic blue's much clearer and brighter. and they are about the same as buying the normal narva H4's anyway
took my 80 for a wof at VTNZ yest with the +90s and they never said a thing.... The bigger bulbs do give a whiter light further into the lenght of the light pattern, giving a better view of all things further away
