Hi all, i am looking for this part asap currently im just going without one and im not sure what damage if any? i am doing when driving around.
It is the shim that goes between the caliper and the brake pad.
I am located in chch and can be contacted on 0273438365
Pierre.
Front right brake pad shim wanted sj413
Re: Front right brake pad shim wanted sj413
I stand to be corrected, but I understand that the shim is merely an anti-squeal pad and you should be doing no damage by operating without one.
Anyone know any different?
- cool__bananas
they are just to stop the squealing vibrations, it doesnt matter much but if your brakes squeal then you should put them back in of get earplugs haha
Ah sweet as then it can just stay like that, cheers guys.
