What did you do to your Jeep today?
Re: What did you do to your Jeep today?
Greased the front end on my TJ. Repainted and greased the rear drive shaft as well. It was just surface rust but was starting to look a bit old.
brake shoes done,bearing in,under it and tightened everything i could, still got a banging noise under it
think i know what it is will sort Sunday... now Ive got a helluva squeak under it as well..universal rubber thing at rear of drive shaft into transfer case
who knows but its a shit of a noise......
v8 tj...luvs the gas......
- downunderxj
Fitted a new oxygen sensor to the Cherokee, had noticed fuel consumption was getting worse, and it just didn't have the up and go I expected from the 4.0l. Also quite sooty around the exhaust tip.
So a new Bosch oxygen sensor from Summit Racing in the US. Cost me $US 68 shipped to a friend in California who then put in the post for a further $US 8.
Took it for a blat around the block, what a difference, this thing has some real up and go now
. Don't know why I didn't pick up on it earlier. Now need another trip up to Taihape to check out the fuel consumption.
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
got filthy top to bottom front to rear, and a fair bit of the inside too.
Blatted round some maize fields preparing the tracks for the food drive fun event. Bog run, figure 8, sled pull, logs, tyres, speed section and drags will all figure. Today was spent "assisting drainage" in the wettest of the two paddocks, and trialling the drag area..... and a few hours cleaning up after.
Tomorrow i hope to pull off my rock sliders (to dontate to RJ) and will start building my new ones.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
yeti wrote:im open to donations mark...
They wont fit on the XJ mate. then again, gimme some dimensions and ill be happy to make some for ya, as long as you dont mind waiting (months), 'cause it would just be done in spare time. Failing that, stop buy and we can measure em up here!!!!! (excuse for the legendary ROAD TRRRIPPPPPPP!!!!)
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
plans are under way , heading up north for xmas road trip.....
hope jeep gets further than last years trip...
yeti wrote:plans are under way , heading up north for xmas road trip.....![]()
plenty of time for me to make some sliders for ya then!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
xj wrote:yeti wrote:plans are under way , heading up north for xmas road trip.....![]()
na ,just a big tow rope mate
Finally got a WoF yesterday! Failed twice last weekend on rear brake imbalance so I took the lazy option and left it with someone to fix. Probably just as well as they fixed it my machining the drums. I also took the opportunity to get the alignment done while it was there so for the first time since I got it the steering wheel points straight ahead when the front wheels do.
Today it's probably just going to be used rather than spannered on, but just to take the trailer to the tip a couple of times.
I might get round to putting a front recovery hook on as a temporary measure until I get two proper mounts to spread the load and I need to adjust the rear muffler hanger as it rattles against the new rear springs for some reason - presumably it got levered against somehow when I was swapping the old ones out.
Fen
'03 TJ (gone)
'96 XJ
'90 951
'03 TJ (gone)
'96 XJ
'90 951
yeti wrote:fitted these
Ohhh, theyre very shiny!!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
just how jeeps gonna stay :
not....off for wof next week,
Man thats a lot of bling!!!! WoF guy might be blinded by the shiny new disconnects.
hope not tj , he sold them to me..put some new bits in the steering arm thing and clunking noise is gone ...........
how dare you yeti... its not a Jeep if it doesnt "clunk"!!!!!!! PUT THAT CLUNK BACK!!!!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
nice one xj
..have you ever taken window winder motor thing out...man they put those suckers in good....now we are going to run a book to see how long before next thing breaks from when i get wof....neighbour has got his money on way home from wof shop.... :
ill put in..... the next day its hiosing down with rain and the wife has to go get a bottle of milk... and it breaks down forcing you to go out and get soaked rescuing her.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
good news got wof today... bad news main seal rear seal or whatever its called leaks now, good news is that they still make oil ,cause i aint in a hurry to take trans out again to fix it.....
Good news, got the WoF for the TJ this morning. Bad news (or better news, depends on the perspective), front lower control arm bushing on axle end is starting to show signs of stress (minor cracks are evident). I have been told to replace them before the next WoF. So I guess I will have to change them with (or change the bushing):
http://www.rokmen.com/products/suspension_systems/rokmen_control_arms/rokmen_control_arms.html
- downunderxj
Good excuse - I thought I was going to be up for that this last WOF because the previous one had warned me they were on the way out. However this WOF failed with other issues but the bushes didn't even get a mention. Oh well!
Gave the old girl a polish, pre the Charity Food Run next Saturday. Then ordered (finally) my upper front and rear adjustable control arms so I can then get around to fitting up the hi-clear skid plate. (THEN the mission will be complete!!!!)
After much too-ing and fro-ing I settled on these fellas http://www.ironman4x4fab.com/TJ_Inventory.html not only was their shipping quote out of the US far cheaper than anyone else (previous shipping quotes ranged from $260USD from Rustys to $160USD from Quadratec) coming in at $125.00 for shipping and totalling $523NZD all up. I decided to stay away from the "johnny-joint" version primarily because it seems there is no-one in the southern hemisphere that do them for replacement parts. The design of the bushes in these seem to perform on a par with the johnny-joint version when $ for $ comparisons are evaluated.
Another reason for going with ironman4x4fab was the promptness of response and how Andy was prepared to go into detail about the product when asked for some more info. His service was outstanding.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
JK RACE Engineering do them is this to late
xj wrote:http://www.ironman4x4fab.com/TJ_Inventory.html
Look good. I deal with Rokmen for the same reason, its a very small manufacturer and they take pride in their work. Dave is wonderful to deal with (was very helpful with the gas tank skid). Rokmen have a version with rubber bushing on both ends. I try to stay away from poly bushing now (like you are staying away from Johny Joints
I wasn't aware of JK Racing making parts for Jeeps (commercially). Might have to talk to Bernie.
TJ wrote:I wasn't aware of JK Racing making parts for Jeeps (commercially). Might have to talk to Bernie.
Im sure Bernie has all sorts of things hidden away that we can only dream of TJ. Never had a problem getting Poly bushings here. Some might need an overnight freezing and a trim but they do the job.
Yes Coxy, too late for me, order is in and money has exchanged hands.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
xj wrote:Im sure Bernie has all sorts of things hidden away that we can only dream of TJ. Never had a problem getting Poly bushings here. Some might need an overnight freezing and a trim but they do the job.
I have seen Bernie's handy work on his Jeep, just didn't realise that he was making and selling components as well. Hmmm....
Anyway, found another brilliant idea for the rear shocks to keep them away from spring buckets:
http://www.shocksandsuspension.com/productinfo-item-43_dc-1.htm
Not today, but yesterday I got confirmation from Greg that he has JKS diconnects in stock and also a YJ rear brake hose so I have those on the way to me.
Other than that I saw the XJ today while I was busy doing other stuff...
Fen
'03 TJ (gone)
'96 XJ
'90 951
'03 TJ (gone)
'96 XJ
'90 951
I just cleaned mine, but I wish I COULD do something like this. The guy has done everything in 3.5 days.
http://www.jeepforum.com/forum/f9/finished-6-1-hemi-conversion-856024/index3.html
Listen to the start-up sound on the video linked in the first post. This is beautiful. The guy bought a two post hoist to do the job in his garage!
took mine out for a play yesterday... and quess what ...............it still goes today
yeti wrote:took mine out for a play yesterday... and quess what ...............it still goes today![]()
WOOOHHOOOOOO
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
