Okay... another question - should the steering naturally return to centre? I've been driving the vehicle a bit over the weekend and one thing I noticed that I was struggling to keep up with the steering when you do a U turn (or similar). After driving it a bit more I realised that if you turn into a corner and take your hand off the wheel it continues in the direction it's turned... no more natural return to centre. I'm not sure if this is a WOF/LVV issue but it doesn't feel quite right. I know you can get the return to centre dampeners for 4WD's, but there could be a couple of other things at play here, like:
- wheel alignment has been done with the eye-cromoter (technical term for by looking at the wheels and saying they look about right)
- I've adjusted the preload on the PS box too much
- I've no steering dampener fitted.
Has anyone who's done a PS conversion experienced this, and does anyone know if it a WOF/LVV issue?
Here's a photo of the old bull bars... They'll be replaced with something new that will tie into the side bars at some stage.
The brakes still aren't that good. I've put in the new pads and tried to get a mobile disc machining service to do the work but they decided they wouldn't be able to fit their machine to the cruiser. To take it in to ABC in Wgtn they quoted $300 for an on the vehicle machining job (eek!) I'll phone around as I was hoping to just take the discs in to get machined but when I had the hub off I relaised that you had to punch out each of the studs... and the first one I tried didn't budget that easily so I reassembled the whole thing.
