Is this shaft good or toast?
brakes-shocks-lockers-etc
Andrew1706
Post by Andrew1706 »
This is the diff head side of the long side driveshaft from my 80 series.
History: Lots of driveline backlash resulting in stripped axle flange and cv spline. Wear on opposite cv spline and flange although still meshing.
I'm replacing with new cvs and flanges but now I wonder if this is okay.
The short side shows slight wear but not as bad the long side.
I've rebuilt the whole diff minus diffhead and my argument is if/when I fit an air locker then the head will be rebuilt then and of course will have to replace the axles then?
Jafa
Re: Is this shaft good or toast?
Post by Jafa »
Thats fawked, look at the difference in the size of the flat on top of the spline between the worn area and the rest. Chuck some better ones in... my 2c
021 273 9942
jafa@inspire.net.nz
suzolla
Post by suzolla »
Thats a bummer Andrew, all starting to mount up, will need to have a close look at mine.
Would pay to check the spider gear that the axle fits into.
Have sent you a PM.
mike
Last minute Mike
Post by mike »
needs to be a nice fit otherwise fretting will occur. once there is backlash the combination of all the backlash in the drive train and the sudden application of power will result in breakage. sure might not happen in toytoa but bloody land rovers are shocking for it!
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
wopass
Post by wopass »
mike wrote:needs to be a nice fit otherwise fretting will occur. once there is backlash the combination of all the backlash in the drive train and the sudden application of power will result in breakage. sure might not happen in toytoa but bloody land rovers are shocking for it!
hahhha, no pun intended there i bet either :lol:
