Diff filler bolt/plug removal (rounded corners)
williamhamilton
Post by williamhamilton »
Howdy.. I want to refill my diff but pain is that the corners on the bolt are a bit rounded and I do not want to abuse more than it has already been and getting all the blame for f^&king it up :)
What is best way to get it out and are replacements readily available? - FJ40 full floater.
At this stage I was considering taking diff head off and having the centre drilled out.. seems extreme but I am not a mechanic or engineer :)
tia
W
chrome
Re: Diff filler bolt/plug removal (rounded corners)
Post by chrome »
if your considering getting it drilled out you may as well have a go youself first crc and some good taps with a small hammer might loosen it up some then vice grips it out, then go buy another bolt.worth a shot
DIRTY OLD HILUX
022 519 7700
chevrolux
Post by chevrolux »
i used an angle grinder to make the sides flat to fit a crescent :lol:
chrome
Post by chrome »
yea id do the same :mrgreen: , it didnt look like he had much tools. everyones got vices and a hammer usually
DIRTY OLD HILUX
022 519 7700
nstacey
Post by nstacey »
6 sided socket... makes all the difference
85 Hilux single cab
02 Grand Vitara
smurf182
Post by smurf182 »
Definately try a 6 point socket and if that fails maybe a cold chisel and hammer.
muddyplumber
Spring Free
Post by muddyplumber »
i rounded mine off aswell, tried vice grips etc ended up welding a rod onto the bung.worked a treat then replaced the bung
williamhamilton
Thanks for the feedback guys. As yet I have not totally naffed the plug but have used spanner and socket (CRC and hammer of course :) ) to no avail - just does not budge.
My main priority was not to round them more than already - but I think I will just have to give it a bigger bash and if I round them then deal with that :) in whatever way is best. Vice grips then welding it seems. Roll on Thursday so I can get back under the diff!
W
gimmemud
Post by gimmemud »
I've got an awesome crescent socket set. It grips the middle of the bolt instead of the corners. Got a couple of bolts on my truck that are a bit rounded and that set works every time. You should be able to buy single sockets from an engineering place.
chrome
Post by chrome »
yeah i gotta spanner set that picks up the flats too. its called metrinch used it on heaps of rounded nuts when i ownwd poxy old cars :mrgreen: escorts and corrolas and shit
DIRTY OLD HILUX
022 519 7700
GotFlex
Post by GotFlex »
I would weld an old nut on top of the stripped pluf and then use the new nut to crack it of, then pop down to toyota and get new one
sambo
Post by sambo »
when one of my manifold bolts rounded i just got a size smaller (or maybe it was an imperial) socket and just bashed it on with a hammer :lol: :lol:
pos nissan patrol
Ln106 single cab
albundy
Rolly Polly
Post by albundy »
Will Nissan plugs fit in to toyotas??? I only ask as nissan bungs have a square hole that fits a socket holder perfectly and nissan bungs don't suffer this problem because of their design.
AL
williamhamilton
Thanks for this guys, not getting any time with the toy at the moment but hope to get another bash at this within the next couple of weeks. bought a new bit of bling which I will add to my build thread once I pick it up next week :)
Welding nut and (possibly) adding Nissan part sound like a good idea based n the design features (I will just have to be prepared to take the stick from the Toyota lads for having Nissan bits on it)
W
Return to “Tool Shed”
