snapped drive pinion fj 40, 1974
kruza wazza
Post by kruza wazza »
just been out and snapped rear drive pinion
would the drive pinion out of a spare front diff/ same ratio work or not?
yours in HP
warwick
Pedro
Re: snapped drive pinion fj 40, 1974
Post by Pedro »
kruza wazza wrote:just been out and snapped rear drive pinion
yours in HP
warwick
Ideally you would put a matched crown wheel and pinion in for smooth and quiet running, if how ever you have a crown wheel and a spare pinion from different sets then rock on, life span may not be great, it may be noisy, i have done it in a vehicle years ago and could not hear it over the V8 anyway,
Pedro
Bulletproof
Post by Bulletproof »
yours in HP
warwick
You cant just fit the pinion by it self because they are a matched pair with Crownwheel so you have to fit both.
Cheers Richard
Never say die, up man and try
kruza wazza
but the crown wheel is diff ?? or not ,??
Bulletproof
kruza wazza wrote:but the crown wheel is diff ?? or not ,??
Up until 1990 cruiser front and rear diff had the same ring and Pinion.
After that they had a reverse cut in the front
Cheers Richard
kruza wazza
so , remove axles then diff head and swap ? front spare to rear ?? W
mickey
Post by mickey »
will work if the rear diff is full floater.
if semi floating it wont work.
kruza wazza
what is the differance?
Bulletproof
kruza wazza wrote:what is the differance?
If you look at the stub you will see the Axle has a flange that is bolted in on a fully floating. If you undo those bolt the axle will pull out.
On a semi floating they have C clips in the diff that holds the axles in.
Big Difference and a Semi floating won't fit in the front diff.
Cheers Richard
sig
Jeep Jeep
Post by sig »
you can use the front head in the rear .just need to run the block and pin in between the side gears and make sure the side gear shims are a snug fit when installed
Return to “Toyota”
