engine tests
Heath
engine tests
Post by Heath »
leak down of 96,90,94,94
compression of 520,500,515,515
Any cause for concern with no 2 down a little? Is that within expected range?
DieselBoy
Re: engine tests
Post by DieselBoy »
I'm guessing, based on your other post this engine is in a Prado??
Is it a 1KZ-TE??
Compression's are never perfectly even.
I would be relatively happy with the figure's on an older second hand Jap import motor, it could just be a bit of bore glazing from lot's of slow running in traffic and usual engine wear.
It could be an indication of somthing more sinister though, so i would get the water jacket tested for presence of Co etc etc
If that checks out ok, then i would be happy with it. It's not perfect, but then its not new either!!!!!
Heath
Re: engine tests
Post by Heath »
Yeah its a Prado 1hz te.
Spreading the search a little from just Pajero's now.
Bulletproof
Re: engine tests
Post by Bulletproof »
Heath wrote:leak down of 96,90,94,94
The max variation is 70lbs so it is probably not a problem.
But as Diesel boy said ,get a CO2 test because prado's crack heads all the time and that can wreak a bore in 2 seconds
Is it using water etc ? Is it over heating going up hills ?
Cheers Richard
Never say die, up man and try
vvega
Re: engine tests
Post by vvega »
10 % is the factory variation
but yeah as above ..
even a tk test is problomatic
Kiwi4x4
