4d56t not starting
h8ruba
4d56t not starting
Post by h8ruba »
hi all
i have just replaced the head and injector pump on my 1990 mitsi pajero
i have timed up the engine accoring to all timing marks on block and head but it still wont start
i ahve primed the injector pump and have deisel coming out of all four injectors
engine has sh*t loads of compression and everything seems as per usual except the f. ing thing wont start
has any 1 got any other suggestions????
thanks all dean
SV1K
Site Admin
Re: 4d56t not starting
Post by SV1K »
Have you hooked up the glowplus wire? Tried glowing it more than once?
8)
tomsoffroad
Flopsie
Post by tomsoffroad »
Did you get the timing right? I did a cambelt on one couple of weeks ago. They have a timing mark on the bottom cam pulley and another mark on the splash washer behind it? Had to do a trip to the library to find out which one to believe. :oops: :oops:
Also this one had problems with the glow plug timer turning off way too early. Put a push button it which sorted it. Its done 300 000km and takes about 15-20sec glow in the morning.
Good luck
Tom
h8ruba
Post by h8ruba »
i have had it jump starting off my hilux so i didnt worry about the glow plug wire. and i have also taken bottom pully and cover off to confirm the timing with the crank pully and markings on the block.
will try hooking up glow plyg wiring tomorrow and hope thatr helps
mudbugga
Post by mudbugga »
Here's the manual I put up on here a while ago. Might help you.
Just remember the basics.... air - fuel - ignition. It has to have all to get it to go. If you've got good comp and there's fuel at the injectors, possibly a timing issue.
http://www.offroadexpress.co.nz/Forums/ ... 24&t=16827
or
http://www.mediafire.com/file/zjoj0qcqzmx/4D56T Manual.pdf
NJV6
Post by NJV6 »
Are you sure it is not 180 out, I did exactely the same as tomsoffroad the 1st time I did one. You soon know by taking the intercooler pipe off and seeing if it sucks or blows.
Once you are certain its right, why not give it atow start? Even without glowplugs that gets them fired up pretty promptly.
An old 4D56 won't start at all without glow plugs.
