Hilux IFS elimination.
haynzy
Re: Hilux IFS elimination.
Post by haynzy »
Jerry wrote:If you want we can drag Taz01 and a welder up to do the welding if you want... he is a ticketed welder which the cert guy may require......
the welds just need to be done by someone competent :wink:
Jafa
Post by Jafa »
haynzy wrote:Hey Ryan, Lookin good
From when I did it just check the shackle angle before you weld the front crossmember in as by the dimensions trail gear gave me for mine it was wrong and the shakle geometry would have been all wrong. But yeah looks good and it has the right badge on it this time :mrgreen: :mrgreen:
Haynzy is right Ryan, double check your spring fit, especially as your not using TG springs, you may need to move the chassis mounts or the crossmember. Should tack it all and then bolt all the bits in to check, nothing worse than having to move something after its fully burnt in..... :roll:
Looks like you let Shaq parctice his welding did ya? :lol: :lol: :wink:
021 273 9942
jafa@inspire.net.nz
Engineer
Post by Engineer »
hows this coming along?
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
wisard2
Post by wisard2 »
Pretty much all finished except for some remaining bar work, and an engine repower next year.
Before; running 31's Image
And pretty much finished; running 33's Image
92 swb Pajero ute. 3 litre V6 manual. 33" Mud wranglers, Diff breathers, Snorkle, 9500lbs electric winch, Rear diff lock, CB & PRS radio's.
