project hardrock
For all Daihatsu related topics.
2roky
project hardrock
Post by 2roky »
85 daihastu rocky
solid front diff stiff as suspension, no ground clearance small feet. being turned into a mud eating monster.
waste of time modifying you may say? well its mine and i'll make it as big and as bad as i can afford to at the mo
list of mod's so far.
31" pirelli scorpions or 750 michallin X's depends on the day to what i'll use
hilux rear springs with 3 leaves removed all round
long shocks in the front
3'' longer shackles
flipped steering set up
custom $40 pvc snorkle
moved diffs
front forward 2-3"
back backwards 2-3"
attitude to boot
still to come
longer drive shafts
longer brake lines
cut gaurds
rear to be cut off and turned into a proper well deck
winch
roll cage
more attitude to boot
standard with longer shackles in place
new shackle
2roky
Post by 2roky »
scratch the tyres for it now got a set of 33'' monoform mongrels for it
hehe bring on the mud :twisted: :twisted: :twisted:
and got a set of 60mm body lift blocks being made
at the moment
Heath
Post by Heath »
For shackles that long you may want to weld/brace them in the middle so they are one piece. might wander all over the place if they slop around while driving on the road.
2roky
Post by 2roky »
doesnt go near the road as isnt leagal but da few times i drove it while being towd didnt feel to bad
Heath
Post by Heath »
Sweet as, just thought to mention it. I know off road the longer shakles give a much smoother ride. Also saw an article on the outerlimits suzuki forum about moving the shackle hanger 50mm so the angle is more pronounced to give better downward travel. Seemed logical so maybe something I will try when all my plans come to fruition (the Missus weakens and says yes I can get a new truck).
2roky
Post by 2roky »
which way ya move it back or forwards
n ya have any other ideas that may help me out with me build that cost very little to do n can/ could help it
Heath
Post by Heath »
I believe you move the shackle pivot point on the chassis closer to the fixed end of the spring but I would assume that the spring pack would have to be soft to get the maximum amount of flex.
The link to the zuk spring story is (stuff is part way down)
http://carl.outerlimits4x4.com/viewtopic.php?t=110437
check out their diahatsu area also
http://carl.outerlimits4x4.com/viewforum.php?f=18
Heath
2roky
Post by 2roky »
just an up date on progress on the project.
got the body lift in and bolted down.
still have longer drive shafts to make and the custom rims to weld back to gether
2roky
Post by 2roky »
giday time for another up date got the new rims made and finishd their on the truk along with the new tyres the backs also cut off and the brake lines have all been lenghtend
meece4x4
Post by meece4x4 »
looking good 2rocky :) thats some beast now
whats involved with the body lift? im looking at maybe a modest 1' one (mainly as they seem to sneek past the local wof shop without notice)
After the weekend performance i really need more ground clearance, I have a set of hilux springs coming from a club member but as Ive just been diagnosed with a hernia i cant fit them yet until I recover from the operation :(
at least I will be able to fit my winch this weekend should be here tomorrow or thursday... father-in-law has offered to do the lifting of the winch into place once i make up the mounts for it, I had a poke around under the front bumper and I think there is enough room to hide the winch behind it with having to modify it much :wink:
shame we live at the oposite ends of the country .. would be good to catch up and have a good look at ya beastie'(s)
2roky
Post by 2roky »
the best and easist way to get more ground clearance is tweak the torsion bars and big feet,
as for the body lift there are 5 blocks a side its just a matter of pulling the old ones out and get some new ones. i used white nylon blocks for mine ya can see the front one in one of the pics but id recommend that you go to a wreakers and try and find larger rubber ones will kep the ride a litle soffter and vibration free
WACKO
Pyro
Post by WACKO »
what size feet you manage to squeaze under there?
2roky
Post by 2roky »
i've managed to fit 33x12.5x16 to it just have to trim the gards to suit now
nivaman
Post by nivaman »
Hey roky
You have done well with those mods, My Fiva is nearly finished and am keen to head out wheeling with you again.
2roky
Post by 2roky »
cheers its not quiet finished yet still have to chop the gards and rollcage it also need to do the drive shafts then its all go and mud will fly
2roky
Post by 2roky »
all done now just going through the process of finding the kinks and ironing them out
damage report to date is
one rear drive shaft and steering shaft rubber bush thing
still a few touch up not jobs to do like securing the rollbar properly putting a perspex window in the back etc
the final result looks like this
Nailz
Post by Nailz »
Thats a pretty sweet piece of hardware you're building there dude. Wish i could build up something like that, Just its a bit dodgy having a vehicle on a trailer in Porirua, The locals tend to borrow them....
Don't Drink And Four Wheel Drive, Those Broken Bottles Are A bitch To Clean Out Of Your Truck.
2roky
Post by 2roky »
cheers for that mate just aframe it then or tie a dirty great big unhappy breed of dog to the draw bar :lol: :lol: :lol: :lol: that should stop the locals
Smurf
Post by Smurf »
thats some good flex out of a lil truck. Good work 2Roky
meece4x4
Post by meece4x4 »
Smurf wrote:thats some good flex out of a lil truck. Good work 2Roky
second that ... thats one serous looking Daihatfoot now :shock: :shock: :shock:
2roky
Post by 2roky »
cheers for that guys
still got a bit more flex left in it i think as that was done with only front wheel drive as im still waiting on the new drive shaft
2roky
Re: project hardrock
Post by 2roky »
since last post ive done a little more to the beast, put the fuel tank on the deck, not ideal for center of gravity but needed to do it before the rear diff knocked a hole in it, have a winch for it now just have to get a drive cog for it ( anyone know of any their like rocking horse shit to find) longer shocks and beefed up front shock mounts n place. just have to reposition the mounts higher now as i dont have enough up travel and they bottom/top out
2roky
Post by 2roky »
this build seems to keep on going,
now have the pto winch on it just need to pull it appart and cut the cradle down to reduce the dist it sticks out and build a new bullbar for it.
this coming year it is going to become coiled i think as well
benorange
Post by benorange »
looks like a good wee truck do you have soa looking at putting hilux diffs under mine and doing soa
2roky
Post by 2roky »
nope its just the standard diffs with extended hangers and large body lift, im thinking i might change to safari diffs as i keep breaking cvs and axels and coil it at the same time
benorange
Post by benorange »
much work in doing it? have you looked into it? i should prob do something with mine cos if you break them with standard motor mine wont last long with v6 turning them. do you need any motor parts i got a good runner here 2.8 turbo
2roky
Post by 2roky »
not too sure being that mines only a offroader i can do it how i like, but if your going to keep yours leaf sprung there is bugger all in doing it and you'd be better going to hilux or 80 series diffs as they are slightly narrower than the safari so cert wouldnt be as much of an issue,
could be interested in the whole motor at the right price
either that or just the turbo and intake manifold and oil lines for it
2roky
Post by 2roky »
forgot to add my tyres are putting a lot of stress through the axles being 33x12.5 mongrels when they bite they often bite pretty hard, twisted a rear drive shaft up one time, the other problem i have is my drive shafts must have a lot of movement in them as they keept spiting the bolts out even if they are loctited in, might have to go to nylocs and see if that helps
benorange
Post by benorange »
make an offer on motor if you want if you in roxburgh i could meet you half way or right price i could bring it up
pm me bout it
Andrew1706
Post by Andrew1706 »
I used 60 series cruiser diffs in my Blizzard.
I moved the rear mounts on the chassis out by 70odd mm but the fronts are identical
http://www.offroadexpress.co.nz/gallery/fat-blizzard
Return to “Daihatsu”
