I picked up a brand spanking EWX9500-Q for $800 and I've got the Runva mounting plate for it to. I want to put it on the Prado which has the standard bumper. Basically what do I have to do? I think there are some holes on the bottom of the chassis rails which the plate can be bolted to, but then the winch will be hanging underneath. Is that ok? Or should it be up on top? Which will involve a bit more cutting me thinks. If it goes underneath, only the bumper has to be cut to accommodate the fairlead.
So whats everyone else done? Photos are good too
1993 Landcruiser Prado LJ78: 4" lift, Tough Dog sus, 35" BFG muds, ARB air locker, LSD
wjw wrote:initially I had a plate between the chassis rails and cut a hole in the factory bumper for the fairlead. I have now moved on to a custom bumper...
Bill, do you have a pic of your custom bar? Cheers Rowan
I run a pto so a bit different but went full custom bar, handles running along clay banks and the odd tree alot better than the standard bumper. Also better approach angle.
