And its just too inflexible... I need more flexiness... and a softer ride... so coils it is.
The Plan:
I have a new 2nd hand Surf wide axle housing coming, to which I will attach some new products... so new they don't even have pictures yet... namely, link tabs: ie the nice 5mm plate tabs you weld to axles to mount links, and beefy-arse links (Al, you will be pleased to know: NISSAN GQ bushes
I'll use 50mm lifted Surf coils at this stage, because they are cheap, plentiful and the weight of the rear of the MU will be similar to that of a Surf. I can easily get surf coils made to suit whatever length I need as well.
The shocks, I'll probably fit some GQ rears straight up and down for max travel. The ones I have in there are longer by a few mm, but are leaf-spring shocks and will probably be too harsh.
Into the new axle I will fit a standard open 4.88 diff, with Lokka - the LSD I'm using is just not diong it for me... so its for sale, 1 V6 carrier heavy duty and recently rebuilt Hilux LSD 4.88 diff... PM me offers, make em sensible.
Updates to follow... slowly, but in time for the mudplug
Steve
