difficulty changing gear
wagonsnz
Post by wagonsnz »
hi guys
I drive a manual 2.4 TD surf, and am having trouble changing into 2nd gear, either from first or down from third. It generally only is difficult when cold, after the engine warms up a bit it doesnt seem to be a problem. I dont want to force it, so I usually release the clutch and try again, but this is obviously a bit of a pain and I'm worried it could be a major gearbox problem? The other gears seem to be ok. I have checked the transmission oil level which is fine. Any help or thoughts would be appreciated..
Andrew
curly12
Re: difficulty changing gear
Post by curly12 »
Drop you oil and give it fresh load. The oil may of never been changed since the factory............. :roll: :roll:
Could be the grade of oil in it, I've had Penzoil recommended in the Toyota boxes as the slightly thicker and is better for it. One of the features of this is that its haarder to change gear when cold......so it could be fine.
If you don't know when it was changed last may be worth changing it
wopass
Post by wopass »
the oil in the Gbox is to thick when cold which makes it hard to change gear due to synchros not spooling propperly so...
drop the oil out of the box and replace it with some nice new stuff of the correct viscosity :wink:
or get your hands on some castrol VMX-M and that will sort it out for you :wink:
wagonsnz
Post by wagonsnz »
ok thanks guys, i will change it tomorrow all going well. what is the best oil to use then? what should i be looking for?
Andrew
Return to “Tool Shed”
