Help no gears
- tara13
Help no gears
Hi wondering if anyone else has had this problem put new clutch in did two trips could still smell clutch burning smell sometimes then driving along in sand went to change gear when i took foot off clutch nothing there no forward or reverse gears .It is a 1993 3.0 super select soft top pajero petrol cheers guys Gareth.
Re: Help no gears
tara13 wrote:Hi wondering if anyone else has had this problem put new clutch in did two trips could still smell clutch burning smell sometimes then driving along in sand went to change gear when i took foot off clutch nothing there no forward or reverse gears .It is a 1993 3.0 super select soft top pajero petrol cheers guys Gareth.![]()
is the slave cylinder on the clutch failing as i have just had to replace mine ... check clutch fluid , and other clutch parts
Re: Help no gears
as for the clutch burning did you get the flywheel machined when replaceing the clutch ??
