50mm extended shackles rugger....
For all Daihatsu related topics.
RuGarBo
Stropper
Post by RuGarBo »
Does anyone have or know of anyone with a set going cheap for my low low budget. and what year hilux leaf springs to use as ive heard this is the way to go ???????? :?: :?
2roky
Re: 50mm extended shackles rugger....
Post by 2roky »
if you go hilux springs it will give you a bit of a headache as it changes the center bolt position, you'd be better spending a few dollars and get the current springs either reset or a new set with lift built in,
i went the hilux way on my offroader and it has lead to having to cut the guards to get the clearance needed for the tyres
Return to “Daihatsu”
