Seatbelt mount question
63swb
Post by 63swb »
Hi,
Does anyone have a series landrover that has seatbelts mounted in a way that the top can be removed? I have a series one that has seatbelts mounted to a roll bar, I want to be able to drive my series 2 with no top but I cant think of a way to mount the belts and i dont want to put a roll bar in. any help / pictures would be great!
thanks
Bolo
2XL
Re: Seatbelt mount question
Post by Bolo »
63swb wrote:Hi,
thanks
Would Lap belts work... ( bolt down to the floor )
63swb
Post by 63swb »
Lap belts would work fine, im just not sure if they are legal in the drivers seat??
Bolo
2XL
Post by Bolo »
Maybe have a look around here they mite know ,http://www.ltsa.govt.nz/ 8)
aroma
Post by aroma »
my jeep has lap belts for the front seat no way to fit lap and dia
if they came out with lap belts and have not been changed or rather the ltsa computer for your vehicle been changed to lap and dia you should be ok ask your wof man if no one can help you on here
tallsam66
Post by tallsam66 »
The type of seat belt you require depends on what type were original equipment when the vehicle was first registered.
As a side issue i wouldnt be doing ay 4wding without a roof & NO rollbar....if you roll it youll be dead !!! as happened in canty last yr in a cut down surf.
63swb
Post by 63swb »
Im not sure what it was originally but maybe i will go down to a vtnz or somewhere and ask there. As far as 4wding goes this vehicle is going to be for road use, got a safari and the series one for playing in the mud :wink:
gary_in_nz
Post by gary_in_nz »
hey mate, you should be ok with lap belts for the rover as its part of the original manufacturer equipment, as they were from factory, some had lap belts.
land rovers are just meccano for big boys and just mix and match real easy, so over the years the wof guys wont know what your particular rover came out with from the factory.
motorhead
Canadian
Post by motorhead »
My 69 has a factory mount point on top of the bulkhead just behind the drivers right shoulder and of course pass left. If pics needed let me know.
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
63swb
Post by 63swb »
thanks for all the help so far, sounds like its not going to be too much of a major issue
