TD42 Turbo Kits
TD42 Turbo Kits
What is the recommended, in peoples opinions, best turbo kit for a GQ? I'm not after all out power but low down torque is more important. Bushed or roller bearing turbo? Keep in mind I'm after a complete bolt on kit, AXT, Denco etc.
Cheers, Jeff.
Cheers, Jeff.
Re: TD42 Turbo Kits
Am also highly interested. Have had a basic look on the patrol forum in Oz, yet to check out outerlimits. I have heard that Kaiapoi repowers are doing a turbo kit for them for $3000 fitted. Yet to go and talk with them. Will watch with interest.
Al
Al
Re: TD42 Turbo Kits
Hi From my own personal experence i have had ball bearing turbos and ones with ceramic wheels ,Had nothing but grief with them had the ceramic wheel fall of on 2 turbos ball bearing turbos sieze up would never use them again ,My latest turbo was custum built up here in Auck and worked out cheaper than an off the shelf one and i got the exact performance i was looking for If you want the guys name let me know and ill PM you ..Steve
Re: TD42 Turbo Kits
theres a guy here in nelson driving a safari ute that has "custom safari turbo kits" or something on the side of it, when i remember to grab his number i will post up on here what he says.
Re: TD42 Turbo Kits
albundy wrote:Am also highly interested. Have had a basic look on the patrol forum in Oz, yet to check out outerlimits. I have heard that Kaiapoi repowers are doing a turbo kit for them for $3000 fitted. Yet to go and talk with them. Will watch with interest.
Al
They make up a J-Pipe style manifold like I have on mine for the exhast side,not a cast style one,nothing wrong with them but some people dont like them.
I would up grade to a BB turbo if you have that option.
Shane
- gary_in_nz
Re: TD42 Turbo Kits
heres some pricing i got on a DTS kit>>
Turbo Kit - $3750.00
Fitting of kit - $600.00
(This incl dyno first, Tune pump to suit & dyno after)
3" Exhaust - $225.00
Fitting of exhaust - $120.00
Boost Controller - $95.00
Boost gauge - $40.00
Fitting - $135.00
Prices Are + gst & freight
Fitting - $135.00
Re: TD42 Turbo Kits
Where are those prices from Gary?
- gary_in_nz
Re: TD42 Turbo Kits
tauranga diesel ltd
can contact them via email off this page somewhere...
http://www.taurangadiesel.co.nz/index.html
Re: TD42 Turbo Kits
Safangari had an ATX kit on his shorty before he onsold and left.
It was plainly unbelievable what the thing could do off the line.
Huge urge.
Huge urge.
- gary_in_nz
Re: TD42 Turbo Kits
yeah i did ask about ATX, but these guys reckoned that DTS was better and they do more of those kits, but similar power out put at the end anyhow
- gary_in_nz
Re: TD42 Turbo Kits
Right, i got my kit installed over the last few days. its the dts kit from the above pamphlet.
This is what came out of the dyno report
its running 12psi
Its an absolute dream to drive now, they told me i should be looking at doing the tappets and injectors sometime, get a bit more out of her, which will be nice.
Fitting a new clutch tomorrow as the standard couldnt handle the new power, heres and example.
Driving it home from Tauranga to Gisborne today, 5th gear up a hill revs start picking up, speed doesn't though
so doing some big slippage there.
But it is true what they do say, its almost like driving a different truck. might get a few pics up if it ever stops raining.
Run up on dyno 54kw @100km (10% down on power)
Fit turbo kit. Fit exhaust, Fit boost controller & boost gauge.
Rerun on dyno & tune 85Kw @ 100km 58% Increase.
its running 12psi
Re: TD42 Turbo Kits
gary_in_nz wrote:Right, i got my kit installed over the last few days. its the dts kit from the above pamphlet.
This is what came out of the dyno reportRun up on dyno 54kw @100km (10% down on power)
its running 12psi
Driving it home from Tauranga to Gisborne today, 5th gear up a hill revs start picking up, speed doesn't thoughso doing some big slippage there.
Just Curious.. What was the total cost??
- gary_in_nz
Re: TD42 Turbo Kits
hehe almost as much as i paid for my safari, it was about 5k. i could have done the kit myself but couldnt be bothered i was on holiday!! wanted some time off the tools since im already on them 6 days a week looking after a saw mill!!
Re: TD42 Turbo Kits
at what revs do you get full 12lbs boost?
Re: TD42 Turbo Kits
I also have just installed a DTS kit from Tauranga Diesel. I installed it myself and found it a high quality kit that was very easy to install, only needing the slight moving of some aircon pipes. I also got the 3" exhaust which are actually for the LWB trucks and so required some modifications like shortening the center section and flogging the hangers of the original muffler but was generally pretty easy. The turbo has transformed the truck to drive and power comes on from right down in the basement with no noticable turbo lag ( or maybe thats because my truck is an Auto ) it just pulls hard right from the start. In fact if the truck is idleing in park and the aircon cuts in ( which increases revs slightly ) you can feel the turbo spin up and really start pulling on the auto. My kit with exhaust cost about $ 4000 + gst and about a day for me to install.
You soon forget about the $$$ when you get something that works well.
Next project - XLink
- gary_in_nz
Re: TD42 Turbo Kits
Muzza wrote:Next project - XLink
yeah good kits aye, whats XLink??
as someone asked before about when it gets to full 12 psi, i would say by 2500rpm from memory, trucks off the road for a bit while i wait for cert plate and making up some bars for it.
Re: TD42 Turbo Kits
an Xlink is a modification to how the front radius arms are attached to the front axle. This allows the front axle to articulate more freely and further because the front locating bushes are free to articulate instead of binding up.
From what I have read it is a simple and reliable mod which does not greatly affect road manners ( infact the new XLinks can be locked for road use ). You can also adjust your castor angle when fitting if needed.
I think DaveM was installing one last year ?. I should post a new Topic and see who else has experience with them.
Heaps of info on the Aussie 4x4 sites.
http://www.dobbinengineering.com/
http://www.downunder4x4.net/forum/showthread.php?t=6693
http://www.outerlimits4x4.com search "xlink"
Cheers Murray
Cheers Murray
Re: TD42 Turbo Kits
I looked at the xlink, but as we are looking at taking the hippo to Brisbane next year if we make the move, any mods have to be easily removed to get through their checks, and the xlink needs cuuting and welding done.
Looking into the Superior Engineering arms instead, as they are a good compromise
Re: TD42 Turbo Kits
there is a kit on trademe at the mo
worth looking at
http://www.trademe.co.nz/Browse/Listing ... =248614952
what you think?
worth looking at
what you think?
- flyingbrick
Re: TD42 Turbo Kits
is it any co-incidence that
trademe wrote:
About the seller
tui_man2 (62 )
Re: TD42 Turbo Kits
tui_man2 wrote:there is a kit on trademe at the mo
worth looking at
what you think?
Wouldn't touch one, look very amatuerish and very poorly done.
Re: TD42 Turbo Kits
worth looking at
what you think?
Be nice to have an introduction perhaps, rather than just advertising your products?
- flyingbrick
Re: TD42 Turbo Kits
How much for you to make me a log style manifold like in your tm pics. I need the flange in a weird position but we can talk about that later.
also need pics of how you do your collector.
- flyingbrick
Re: TD42 Turbo Kits
DaveM wrote:I looked at the xlink, but as we are looking at taking the hippo to Brisbane next year if we make the move, any mods have to be easily removed to get through their checks, and the xlink needs cuuting and welding done.
I sorta cant handle the fact that the X link relys on one bolt on the front of the axle...It just doesn't look strong to me. The forces being put through that front mount must be extreme at times to say the least.
Re: TD42 Turbo Kits
worth looking at
what you think?
Lol all three of his posts are the same as above.
Don't just rock on here to pedal your goods. Introduce yourself etc etc or people won't give you the time of day.
Re: TD42 Turbo Kits
He is just whoring his products.
And poorly at that.
Can a mod delete this and his?
Tim.
And poorly at that.
Tim.
Re: TD42 Turbo Kits
flyingbrick wrote:I sorta cant handle the fact that the X link relys on one bolt on the front of the axle...It just doesn't look strong to me. The forces being put through that front mount must be extreme at times to say the least.
Apparently the forces aren't that great on the bolt (just going by what I've read, as others, including myself have asked the question on outers), but at full flex, it's scary how much bow you get in the standard radius arms
Re: TD42 Turbo Kits
That kit on trade me, is a ticking time bomb
Re: TD42 Turbo Kits
haha sorry guys may bad.
how do you think is a ticking time bomb?
thouught it was worth ago.
like some feed back tho.
i done my orignal truck witch is the one in the phot 2years ago an its running 15psi up to 20psi an has never missed a beat an have yet to fing a turboed 4.2 to beat in
an name is abe 22 from nelson
Re: TD42 Turbo Kits
Lynx wrote:That kit on trade me, is a ticking time bomb
how and why o you think this??
can i see yours?
not beeing smart just after you input iv seen most kits round mine is not a kit as souch more custom to what they are after if want big money spent then i make stainless extractors to tuned lenghs but as we are both awear who is after expansive job these days most want good job at bottom dollar an this is easy way to get reliabe an decent at lowish cost
cheers abe
