1991 prado any good?
zimzo4wd
Post by zimzo4wd »
hi im new to 4wding and been out with mates and wanna know if a 1991 prado is any good for off roading it has a 2.8l turbo motor
thxs
philux
Re: 1991 prado any good?
Post by philux »
have a closer look, as far as I know the 91 prado were only made in 2.4 turb, they are normally the 2lt which is the weaker of the 2.4 turbs (compared to the later 2lt-e) but both are still shocking at blowing heads, other than the head troubles they are a very nice truck being 4 wheel coil and disc
check if it has electric hubs and if they work, motor esp the 2lt are known for cracked head issues but these are not a major to replace, or repower ...., do a search on here on 2lt....
capable and comfy.....
DaveM
Post by DaveM »
philux wrote:have a closer look, as far as I know the 91 prado were only made in 2.4 turb, they are normally the 2lt which is the weaker of the 2.4 turbs (compared to the later 2lt-e) but both are still shocking at blowing heads, other than the head troubles they are a very nice truck being 4 wheel coil and disc
Will be this one I'd say. Had an engine swap
http://www.trademe.co.nz/Trade-Me-Motor ... 591560.htm
curly12
Post by curly12 »
The odometer genuinely stopped working about 8 months ago... its saved me heaps in deisel miles but something you may want to fix..
That has dodgy warrant written all over it :roll: :roll: :roll:
if this is the truck then it doesn't mention a cert for the motor swop, which may be an issue or not..., swb ones don't come up too often on TM, 4.88 diffs
zimzo4wd
Post by zimzo4wd »
thxs for the info guys
sig
Jeep Jeep
Post by sig »
possably doesn,t need a cert if the hp gain is less than 20% (from memory or something like that )
mudmike
Post by mudmike »
Would make a good start for a build up, and get you alot of places standard. will take bigger rubber with no mods.
J_Dub
Post by J_Dub »
nice wagon if thats it, coils, turboed 2.8, tidy, worth every cent imo
nstacey
Post by nstacey »
According to carjam its been frozen since early 07 so thats hardly 8 months
85 Hilux single cab
02 Grand Vitara
its_that_guy2
Post by its_that_guy2 »
my 70 cruiser on 34's is possibly for sale ? are ya keen the welly boys have seen it
zimzo4wd
Post by zimzo4wd »
im picking up the prado on friday ...
so hopefully ill see u guys around welly
Sweet...
I have 2 spare speedo clusters if you need parts...., i may have some spare window parts as well, although it may just need a bit of silicone spray in the door bits and down the window rubbers.
Check the front suspension bushes when you get it as well as the body and door drain plugs, find out when the last service was done as well, may be due for all the fluids.
The rear discs have a silly handbrake drum behind it which is a pain in the as5 as you lose your handbrake after the first mud hole, Jafa sells MR2 adaptor plates, however the suburu conversion may be a better fit (well it looks better on mine), the rear handbrake shoes are $$$ (can get then recoated apparantly)
Be ready to smash rear corners and taillights, I did 4 on my old LJ71 and have already done 2 on my current pos, have a chat to Stinky re some hooks and barwook,
Get the rust sorted quickly, have a chat grahem at classic cars if you need help.
zimzo4wd
Post by zimzo4wd »
thxs jerry .
if i needa get a speedo cluster ill get in touch with yah.
im gonna prolly give it a full service when i get it bak here so should be all good
Return to “Toyota”
