I have just bought myself a Autometer oil pressure gauge and sender from Ripco. However I can't get the bloody sender in, the thread on the new sender is 1/8 and matching them up it looks as though they are the same thread the original sender is just tappered.
Any ideas on how to get the new one in and if it is the right type thread??
Cheers Guys!
Oil Pressure Sender
- Disco-Blue
Oil Pressure Sender
Blake - 0274124836
Re: Oil Pressure Sender
i just got a new dacton oil pressure and sender for my rebuilt 80- i believe toyota's use a .9mm thread so we are tapping the adaptor to hopefully get it in... yet another quaility toyota "only ours will fit" scenario
just been through this myself.
Toyota block thread is 1/8 BSPT. (T = Taper)
Sender thread is 1/8 NPT
I got a T junction with a 1/8 BSPT male and female pass through , and a 1/8 NPT tap off on the side
means you can run the factory low oil pressure switch and the aftermarket pressure sensor.
brought the adapter from a specialist gauge shop in ChCh (Parrots) while i was down a few weeks ago. Cost $15. Guy also said that is was no drama to re-tap the 1/8 NPT sender to a 1/8 BSPT thread.
LR110 ..... LJ50 project
- Disco-Blue
Sweet thanks guys, guess I will be heading into Parrots. Thanks!
Blake - 0274124836
UBZ wrote:just been through this myself.
thats what i wanted to say, but lacked the technical lingo, and im also going to run the factory unit as well as my new one
badnuz wrote:thats what i wanted to say, but lacked the technical lingo, and im also going to run the factory unit as well as my new one
It helps when you have it all written down in front of you.
you wouldn't believe how long it took me find that info after my after market gauge wouldn't fit.
Pretty sure most Toyota diff , gearbox breathers etc use the 1/8 BSPT thread as well.
