Basically right now I'm in parts acquisition mode
I feel like its all kinda coming together into something I can start working on now- Its taken me 6 months of question asking, reading and pushing money around the country....
Anyways, this is the truck as purchased. It was covered in dog hair and filth inside and was just really really gross.
I liked the fact it was coil sprung/solid axle f/r, short wheelbase and it had way more power than the early hiluxes I test drove. As an added bonus EVERYONE I'd spoken with about the safaris and every article I read mentioned that they were about as unbreakable as factory jap vehicles get........and the intention was always to EVENTUALLY go a little larger in tire size.
Within about a month I'd pulled off and sold the roof rack, front nudge bar, side steps, bumpers and various other pieces for added project money and/or because they were dragging on shit and getting bent. The GF and I pulled the interior out and gave everything a hose/scrub with soap and I then used VHT vinyl die to spray the front floor carpets and boot carpet black.
The factory speakers were in a terrible state so they were removed and some sony items were installed in their place. The rears fit straight in where as up front I machined off the factory speakers mounting ring and used it as an adaptor.
I bought some uhumpee plastic and made myself some body lift blocks to give 35mm extra hight... and then cut/welded my gear lever to stop it fouling on the rear of its trans tunnel hole. (both now sold.... i think)
I stripped and rebuilt the factory Warn winch as its free spool had locked up. I had to drill two small holes in the end of the housing and then heat things with a torch so I could punch the outer planetary gear ring free.
Everything was then sand blasted, greased and then sprayed nice and black.
And then I fitted a TQ converter lockup switch (well recommend this to anyone).
And it was about now I think that things started going really bad. Parts started being purchased and project holes dug. All of this happened:
New 37" creepy crawlers arrived (thanks Karam)
Shortly afterwards some REALLY NICE drop boxes turned up to push the radius arms down 100mm and forwards around 30mm (just eyeballed it.. unsure how far jsut yet).
http://4wdbits.co.nz/ProductDetails.aspx?productID=1186
I bought a rear Terrano LSD for the front (Thanks Ryan) which has just been transported to Hamilton for me by Taz01.. flippin legend.
Some black steelies from 4WDbits to fit the tires:
http://4wdbits.co.nz/ProductDetails.aspx?productID=1222
Some manual front hubs were bought off trademe and cleaned up REAL well after being stripped/sand blasted and all greased up nice.
Various 4" rubber hose bends were purchased from TRT (iirc) for a home-style snorkel setup.
A pipe bender was bought.
An S14 silvia steering wheel was purchased to replace the crackign/gross factory one. This new one was cheap and is leather bound and black and pretty.
annnnd.
Today I collected these parts from 4wd bits
100-125mm lift EFS extreme struts, and 100mm lift EFS springs (which should give around a 3" lift after sagging/front bar etc)
http://4wdbits.co.nz/ProductDetails.aspx?productID=450
http://4wdbits.co.nz/ProductDetails.aspx?productID=449
http://4wdbits.co.nz/ProductDetails.aspx?productID=465
http://4wdbits.co.nz/ProductDetails.aspx?productID=457
TO DO!:
-Purchase longer rear arms from that fellow on trademe- waiting for his rubber bushes to arrive.
-Have made or purchase longer brake lines
-Purchase new rubber spring hats to remove the DONK my current ones are giving off
-Fit terrano LSD
-Fit snorkel
-Cut my guards out/have the steel lip welded back in by pannel shop (front and rear)
-Purchase/fit a turbo to spin these things. Evo3 TDO5 was purchased but was found to require a rebuild $$$ so sold
-have front panhard mount moved forwards so things dont clash when the diff is pushed forwards by drop box.
-Purchase front/rear adjustable panhards
-GU front axle or longfields.
-etc!
HUGE THANKS to:
4wdbits.co.nz for going out of their way to answer my many questions and for giving me a free steering dampener with my lift package (exchanged for store credit in the end to make upgrading to better shocks a little less painful
Darinz for answering my many PM's/E-mails and providing farkloads of useful info.
Vvega for providing motivational abuse.
Taz01 for doing his bit in ORE's courier service.
My beautiful girlfriend, Hayley, for not leaving me yet
Everyone else who has helped me so far. You guys rule
Unsure if anyones made it down this far. I talk lots
-Flyingbrick
shaved off a number of protrusions in there and did my best to make the ports the same size. ONE THING is pwning my ass tho- look at the left most runner in this pic. Its SUBSTANTIALLY smaller than the rest due (i guess) to the EGR bull shit that was all over it. I've compared it to my non-egr manifold and mines got fully formed runners all the way along.
