Tubes or Tube less?
LIFTED
Tubes or Tube less?
Post by LIFTED »
Just picked up my new Hankook RT 03 35/12.5/15'MT tyres.Waiting for the 10''x 15'' rims to be supplied and wondering does anyone fit tubes these days or isit a waste of time? Have been told if the rims spin the valve will be ripped off the tube! The rims are not bead lockers.
89 SWB Patrol Lpg/petrol 5spd, body lift, spring lift,headers & high flow,Custom front bars 9000lb winch and 4x100w hella spots,custom rear bars and stainless fuel tank,Hankook 35/12.5/15x10 rims.
Re: Tubes or Tube less?
Go tubes mate, with a 35" tyre you'll have to go to heavy duty tubes and you might as well redrill the valve hole in the rim and stick tractor tubes with lock rings on the valve stem into them
With tubeless its easy to pop the bead, lose the air and throw the tyre off when your running lower pressures, most of the guys down here that went tubeless have all gone back to tubes :mrgreen:
J_Dub
Post by J_Dub »
most serious dudes fit tubes, some use MSall (a flexible urethane/plumbing sealant) to bond tyre to rim, or rough up the inside of your rims, so they aint shiney so it aint so slippery, i purposely got overspray on the inside a my rims when i painted them black so it left a non shiney/slippery surface, im running tubes n had no probs
LIFTED
Post by LIFTED »
Cheers guys some good advise thank you.
safaripete
Post by safaripete »
im not running tubes an never have.
havent had any problems yet touch wood
but in saying that i only go as low as 12psi im running an 8 inch rim with 35s
gary_in_nz
Post by gary_in_nz »
some clubs have that you have to have tubes as a rule, my club does for some reason. i pulled my tubes because i was ripping off the valve stems, tried to go down the tractor tube way but everyone i asked about here locally gave me a funny look.
i have reasonably new tires and use to run them at about 10psi with the tubes but took them out and run about 16psi until they start wearing a bit more then air them down accordingly to attain similar amount of traction. thats the plan anyway.
albundy
Rolly Polly
Post by albundy »
Got sick to death of tubes, alwatys getting punctured by the dirt that gets in the bead when aired down or ripping valve stems off. I put my 35 silverstones on to 7" rims. I rouighed up the edge where the bead sits and had the fitters use bead glue. Also ensured they do not use any silicone spray to assist in getting the tyre on. have not popped a bead since doing this and have given the tubes up.
Al
albundy wrote:Got sick to death of tubes, alwatys getting punctured by the dirt that gets in the bead when aired down or ripping valve stems off. I put my 35 silverstones on to 7" rims. I rouighed up the edge where the bead sits and had the fitters use bead glue. Also ensured they do not use any silicone spray to assist in getting the tyre on. have not popped a bead since doing this and have given the tubes up.
Al
dunno how well that would work on his 10" rims :mrgreen: :mrgreen:
albundy
Rolly Polly
Post by albundy »
That's my point, his choices are:
1. tubes and put up with the hassle of them.
2. Go smaller rims
3. bead locks
:mrgreen: :mrgreen:
Return to “Tyres”
