How to cut the guards on my XJ Cherokee
sneek010
Newbie
Newbie
Post by sneek010 »
Hi, I have just tried to fit 32x11.5 to my xj which has a 2" Lift kit, but when a turned the wheels they crash into the guards, can you explain to a total novice how I go about cutting the guards? Step by Step please.
yeti
Bruiser
Re: How to cut the guards on my XJ Cherokee
Post by yeti »
hi mate , have a search through here http://www.ausjeepoffroad.com/forum/for ... .php?f=124
v8 tj...luvs the gas......
Lynx
Post by Lynx »
s
xj
Post by xj »
if you send bb240c (???) a PM he maight be able to help.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
downunderxj
Post by downunderxj »
Try this http://www.naxja.org/forum/showthread.php?t=101158. However it is a bit old and the photo links are broken. HOwever I have a pdf that I could email you if you send me your email address by PM. I have done my front guards, but not the rear ones yet.
Ian
'95 Jeep Cherokee (XJ)
1936 Ford Flathead V8 Colonial Cab (restoration project)
sneek010
Newbie
Newbie
Post by sneek010 »
This may be beyond my capabilities... is there anyone in Auckland I could pay to do this?
DAJEEP
Post by DAJEEP »
its ezy as just get a grinder with a 1mm cut of wheel and start cuting were the tyers rub
flyingbrick
Post by flyingbrick »
way safer, less stressful and easier using a cheap jig saw with a steel cutting blade.
xj
Post by xj »
wherenever i try to cut anything with a jigsaw its goes offline horribly... and thats straight... heaven knows what would occur if i tried cutting on an angle!
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
flyingbrick
ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
If you need a hand in hams and will supply the ginger beer i can pop over 8)
xj
Post by xj »
flyingbrick wrote:ahahahaha. its surprisingly easy. Just mark out the cut with a clear sharp line and take it real slow.
Sadly I am afflicted by the left-handedness... same thing happens when slicing bread with a serrated knife. Come to think of it, the same thing has been known to happen while driving!
(and youre welcome around any time, providing you supply the ginger beer!)
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
Return to “Jeep”
