Hi, where would I get some replacement rollers for a Toyota PTO Winch?
W
replacement fairlead rollers for PTO winch
- williamhamilton
Re: replacement fairlead rollers for PTO winch
for my safari i cut the old fairlead off and welded another new complete unit on had to change the pins and circlips for bolts and nylocks
- williamhamilton
coxsy wrote:for my safari i cut the old fairlead off and welded another new complete unit on had to change the pins and circlips for bolts and nylocks
Thanks Cosxy, I see some cheapy ones on TradeMe. Anything to watch out for?
W
Watch the ones with plastic bushes, they deform and bust under load, also the pins are only held in by clips, is worth changing to sealed bearings and bolts.
Some of them are also made out of thin steel, not thick and they go out of shape wehn the load is transferred through the rollers to steel frame.
Al
Al
yep you guys got all the problems listed with after market ones. so what they say is right
