Supercustom van engine.
does any one know if a supercustom van motor will this bolt straight into my ln61 surf?
Re: Supercustom van engine.
yep bit a changing first ie:oil pickup,sump,engine mounts,to be safe i changed over flywheel clutch etc as well and if yours was turbo you end up with a bundle of unused wiring and no rev counter
WARNING:
is the super custom motor an L series or 1kz? L series will bolt in with Taz01's mods
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Im not sure on motor numbers, but its out of a 94 supercustom, 3.0td?
would that bolt into my ln61 etc?
super customs (93ish on) are 1kz
in that case ignore the above only works in L series
WARNING:
Ok Thanks ANyway mate, Does any one have any info on putting this 1kz in my ln61?
its too hard i wouldnt bother. By what i hear u need to cut and weld mounts n the chassis, wiring is completely different, etc etc. If u can find a 3l or 5l thats not much modification and theyr not far off in power to the 1kz
skux wrote:Ok Thanks ANyway mate, Does any one have any info on putting this 1kz in my ln61?
anything is possible.....its just time and $$$
have a look on http://www.toyotasurf.asn.au/forum/
they have a few who have done the conversion on LN130's. not sure with the LN61, a few things may be different especially gearbox wise.
a 3L or 5L conversion would be easier as there is no ECU to wire up.
Ok, im tryn to get hold of a 5L now.i just sold the super custom engine. What do i find a 5L in so i can inqiure on TM?
I have a 3L in my 84 lux (non turbo 2.8L) its not exactly a speed demon but still (just) manages to pull my caravan around the country (at 95km with a tail wind and 30-40km up hill)...
Its loads gruntier than the 2L though...
Now thinking about putting a V6 holden in just need to convince the mrs its "money well spent" lol - that seems to be a common swap if your looking for a decent amount of power
skux wrote:Ok, im tryn to get hold of a 5L now.i just sold the super custom engine. What do i find a 5L in so i can inqiure on TM?
NA Hiace newer than about 98? Hilux 98 to 2001 or so, newer than 2001 Hilux has the 5LE which has an electronic diesel injection pump which will be more complicated to set up.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
