calling Zuk owners ..strange noise * solved but not fixed*
For all Suzuki related topics
meece4x4
Post by meece4x4 »
Hey all, my Zuk (1600 16V) motor has been making a strange noise lately, just off idle to about 2000 rpm there is a definate whine/vibration/rumble ( Sounds a little bit like a dry thrust bearing) coming from *front* of the motor, if i hold my hand on the plastic cambelt cover i can feel it vibrate slightly as it goes thru the range it makes a noise, however the whine sounds like it's coming from the top cam pulley when standing head on ... from the side it sounds lower :?
over 2000 rpm it's not as noticeable, at idle it's not there either .. 1200-1400 and it very loud
could it be cam tensioner?? or is the front cam bearing packing up?
cheers Meece
meatc
Re: calling Zuk owners ..strange (almost supercharger) noise
Post by meatc »
Pull the crank pully and check the keyway. They are known to shag out. Can evidentally be fixed with a bit of that liquid metal stuff. (may pay to check the crank timing belt pulley to.)
meece4x4
Post by meece4x4 »
meatc wrote:Pull the crank pully and check the keyway. They are known to shag out. Can evidentally be fixed with a bit of that liquid metal stuff. (may pay to check the crank timing belt pulley to.)
cheers for that, will check it out.
Heath
Post by Heath »
As per PM, check the tensioner, just incase this has vibrated loose. Check timing marks while you are there to make sure the belt hasnt jumped a notch if it is loose.
meece4x4
Post by meece4x4 »
Heath wrote:As per PM, check the tensioner, just incase this has vibrated loose. Check timing marks while you are there to make sure the belt hasnt jumped a notch if it is loose.
many thanks for that Heath :D going to whip the front off tonight..doubt the timing belts jumped a tooth though .. thing still pulls like a school boy!! :lol:
meece4x4
Re: calling Zuk owners ..strange noise (solved but not fixed)
Post by meece4x4 »
well found out what the noise is ...
the cambelt is rubbing on the plastic shroud :oops: :oops:
now to figure out why and how to stop it :D
lneil
Re: calling Zuk owners ..strange noise * solved but not fixed*
Post by lneil »
Never heard of that one before, just check that the guide shim on the crank pulley is fitted the right way round so as to guide and the belt in towards the pulley before you put the cover back on.
Do you have a spare plastic timing gear cover? it may be that the cover is warped.
meece4x4
Post by meece4x4 »
lneil wrote:Never heard of that one before, just check that the guide shim on the crank pulley is fitted the right way round so as to guide and the belt in towards the pulley before you put the cover back on.
cover was warped ... fixed it with some gentle heat from a hot air gun ..a couple of washers and a rubber mallet! ... all good now :) :lol:
Return to “Suzuki”
