WANTED PTO winch setup- complete.
For all Nissan related topics
DaveM
Re: WANTED PTO winch setup- complete.
Post by DaveM »
Mud Hog wrote:
coxsy wrote:a pto is to small to pull curlys lwb poor things are only rated at 3200kg :D
Flyingbrick were did you get that info from, I was told they are rated for 16,000 pounds which is 8 ton, Thats if 2,000 is 1 ton is right?
Going by the pic of the handbook, it says its rated at around 3300lb not kg, so it will be lifting capacity
apart from whats in the handbook the warn winchs fitted are 8000lb units so the pto's will be the same or + - the line pull of those, and we know the pto's never want to stop pulling us out just the shear pin called it quits well before hand :D
Mud Hog
Post by Mud Hog »
Patroler Post subject: Re: PTO winch strength, rebuilding etc.Posted: 28 Nov 2009 09:15
Newbie
Posts: 1 I agree, some good info on pto's.
But afaik the rating is 15,000lbs (7.5t)...according to my Nissan handbook anyway
GU patrol 35s ect.
flyingbrick
Post by flyingbrick »
Have got a huge hydraulic winch lined up instead. :lol: ..... So never mind.
Return to “Nissan”
