LN61 LIFT
LN61 LIFT
Ive got a ln61 surf with aftermarket rear leaf springs,shackles and 100mm trailmaster shocks. But i need it around 2inches higher? So the front can be cranked up as it has a bolt on IFS lift kit making the front subframe lower but actaul truck higher. So we are going to make the front higher for ground clearance but im not sure what to do in the back.. Thanks
Re: LN61 LIFT
re arch your springs and longer shackles?
Re: LN61 LIFT
Ok cool how do i go about getting them re arched?
Re: LN61 LIFT
A Blacksmith/Springmaker can re arch your springs, be aware that they may sag again after a while.
You could make your rear shackles 100mm longer but that will give you a very soft rear end.
Alternatively, sell your rear springs and buy a set of 50mm raised rear springs
- Bulletproof
Re: LN61 LIFT
skux wrote:Ive got a ln61 surf with aftermarket rear leaf springs,shackles and 100mm trailmaster shocks. But i need it around 2inches higher? So the front can be cranked up as it has a bolt on IFS lift kit making the front subframe lower but actaul truck higher. So we are going to make the front higher for ground clearance but im not sure what to do in the back.. Thanks
Why do you want to go higher ?
It doesn't matter how much lift you go at the back you are not gaining anything because it is ground clearance under the diff that counts.
All you will do is stuff up articulation and with a higher centre of of gravity make it fall over
Cheers Richard
Never say die, up man and try
Re: LN61 LIFT
bigger tyres + body lift. as bulletproof said u want diff clearance, lifting the chassis wont help if ya diffs draggin.
Re: LN61 LIFT
My diff aint dragging at the moment though, its the fact i keep getting bellyed from the front being too low. But i dont want the truck sitting on a mad angle cause ive raised the front but not the back as much.
Its not going to be stupid high, also this is a everyday truck aswell.
Re: LN61 LIFT
take ur leafs 2 an engineer and tell him u wanna raise em 50mm. cost ya bout $150 each 2 get em reset.
Re: LN61 LIFT
oK SWEET, my mate olds own a engineer work shop. What exactly do they do to raise them etc?as we want to have a go on spares to see the out come.(with the help of the engineer).
Re: LN61 LIFT
Have seen a few ppl using blocks in the rear, does that work any good? cheers
Re: LN61 LIFT
blocks would work but handbrake cable would probably have 2 b moved. probably b the cheapest option.
