Hey guys I have a 3.9l v8 land rover motor in my hilux and need some more cooling,Does anyone know what thread the oil filter is on.I want to put a oil cooler on
Thanks,Rob
oil cooler on a 3.9efi
- mike
- Last minute Mike
Re: oil cooler on a 3.9efi
I did work it out a while ago but can't remember what it was. But the best bet is to get the lines from a transmission cooler for the same engine, they plug straight into it. there should be a few of those around. I got the whole transmission cooler (now oil cooler) and lines for $50 bucks from hoskins in chch. the extension lines cost me a bomb though (my dads fault!)
hope that helps a little.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
Thanks bud.Turns out the thread is quite a common one so managed to get a kit easy.
Cheers,Rob
Cheers,Rob
mike wrote: I got the whole transmission cooler (now oil cooler) and lines for $50 bucks from hoskins in chch.
Is it Ok to use a trans cooler for the engine oil? Would be keen to do this if its not just for those dodgey Rover things
