Taieri Rd, Waitawheta
Looked at an old post of a track in this area. Can someone give me an update on this as about 9 of us from Nelson 4wd club are planning to come up for Easter 2010 and this track looked interesting. My truck is probably the baby of the group being a Cherokee with 4.5" lift,simex,warn winch,front locker and a tight LSD.
Re: Taieri Rd, Waitawheta
Its a walk in the park, you'l breeze through it with that
I see that the boys from Manukau 4wd took 12 to 24hrs a couple of Fridays ago - that is - those that only took 12 hours had to wait in the car park for the rest to get through - Chev Blazers are a bit too big for that track
hell that is nearly an average of 1kmh
they took a chev blazer into Waitawheta
again
didn't one run out of fuel in there a while ago
track must be a bit wider all the way through know.
LR110 ..... LJ50 project
the one that ran out of fuel was not filled well to start with
- Bulletproof
Mudzilla ,Jafa and myself did it a month ago in the wet in a little under 9 hrs including the access road.
You will enjoy the drive. Best track I have ever done.
Cheers Richard
Cheers Richard
Never say die, up man and try
Bulletproof wrote:Mudzilla ,Jafa and myself did it a month ago in the wet in a little under 9 hrs including the access road.
Cheers Richard
Bloody good video you have of it there to Richard.
