The Mutts new ground up rebuild
rokhound
Re: The Mutts new ground up rebuild
Post by rokhound »
flyingbrick wrote:Its what the passengers need so they dont sh*t themselves when it rolls.
:lol: :lol: :lol: :lol: :lol:
Rock rings are a Trail Gear item that is sold here by SNR 4x4. They are a replacement for the tin felt retainers that are found on the front of solid axle toyota 4wds. These are of considerably heavier construction and hold their shape much better (helping keep water out of the hub) and will take a knock from stray rocks etc.
Fakey
Post by Fakey »
Oh right thats what i assumed they were but from the photos they didnt look that much different to standard ones so i was unsure :oops:
Didn't barbie drive a jeep??
rokhound
Post by rokhound »
tomsoffroad
Flopsie
Post by tomsoffroad »
Starting to wonder if you are getting abit fancy for us!! :mrgreen: :mrgreen: :mrgreen:
I think that there will be tears with the first oil leak. :wink: :wink:
Looking good, dont listen to me Im just jealous :( :(
86-surf
Post by 86-surf »
very nice. just read the last 5 pages, i am enjoying the pictures, learning a few bits and piece's from them!, time to put some fort into the deathbuggy. . .
badnuz
Post by badnuz »
I Need tissues...... :oops: :lol: :mrgreen:
rokhound
Post by rokhound »
badnuz wrote:I Need tissues...... :oops: :lol: :mrgreen:
Swap ya some tissues for an ARB locker (hint hint) :wink: :mrgreen: :mrgreen:
badnuz
Post by badnuz »
would depend on what is in the tissues lol
niblik
Post by niblik »
86-surf wrote:very nice. just read the last 5 pages, i am enjoying the pictures, learning a few bits and piece's from them!, time to put some fort into the deathbuggy. . .
like this? plenty of fort up there.. as opposed to up there *nibz points at 86surf* Image
WACKO
Pyro
Post by WACKO »
where do you find these things nibs...
loving it rok. looking very cool...
petefj40
Ms Daisy
Post by petefj40 »
Ditto.
Well done on the work done so far!
Very impressive. :shock:
I'll enjoy watching the progress on this build thread for sure.
surf10
Post by surf10 »
How did you adapt your holden trans to your toyota transfer cases?
looks very different to the comon marks adaptor set up
rokhound
Post by rokhound »
rokhound
Post by rokhound »
NJV6
Post by NJV6 »
Cool. 8) Loving the detail (brake fittings, etc)
Glen
lilpigzuk
Tiger Balm
Post by lilpigzuk »
Nice work grunta 8) The ranga coloured chassis/running gear is mint :lol:
petefj40
Ms Daisy
Post by petefj40 »
Looking good.
That centre winch looks trick. :mrgreen:
muddyhilux
Post by muddyhilux »
very very cool 8) ,truley a work of art
Engineer
Post by Engineer »
sweet
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
flyingbrick
Post by flyingbrick »
man, clearance under the diffs is unreal.
you can do that to safari diffs too + trim the rear shock mounts up as well
Steve_t647
Post by Steve_t647 »
coxsy wrote:you can do that to safari diffs too + trim the rear shock mounts up as well
You don't get the same amount of clearance under a shaved nissan diff but they are a bit better built to run into stuff.
I think the mutts trussed diff would be stronger but it will be interesting to see how the internals hold up.
Very nice work and what do you mean about the original fuel cap? pass the wires in to hook up to a battery for a DC Welder or an anderson plug and airline fitting mounted in there?
rokhound
Post by rokhound »
Going to be running a couple of 700 cca plus batteries. One in the engine bay and 1 set into some custom panel work over the passengers rear wheel arch. welder setup will be basic and not sure just how basic yet :wink:
And yes airline fitting for air tools and airline will be in there as well. Still have a fair bit of other shit to yet though :P
surf10
Post by surf10 »
this truck looks awsum!!
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Trying to get my head round your winch Rok. I am but a simple engineer and thinking can be hard....
I take it that you will be able to disconnect the pulley at the rear, from the chassis, then attach it to something else behind you to winch off? And lock the front hook to your chassis, thus pulling in the pulley? Is that the plan?
I assume you are doing this to be able to winch in both directions, or is there another reason for the double back?
I have been thinking about a mid mount PTO for mine, and now you have shown me how it could work.
rokhound
Post by rokhound »
You got it in one John. With a couple of extra blocks you can also winch sideways (albeit with difficulty) and you can set a line and drive it on really ugly sidlings.
Well that is the plan, like the rest of truck it is all wait and see if it works now :wink:
rokhound
Post by rokhound »
Okay this work thing has been a real PIA (but after going down over $2m in the last 2 years, I will not complain that it is getting busy again ;) :lol: )
So any way, here's an update of some progress
Got a radiator shroud made up and fitted, It now has some fans attached as well
Shot of front guard which has been reshaped at the front, The axle is so far forward now that I don't have to even flatten the seam in the wheel arch which you normally have to do just to fit 33"s
Rear guard reshaped with new fuel filler in and exhaust exit flushed off
Painted all the door shuts and inner guards, and interior etc. This is a major job :roll:
Transmission oil cooler lines for the auto
Holden air con pump for OBA in. It is a sanden but not an SD unit, so I have fitted an oiler etc and we shall see how it goes I guess
It is getting quite full in here now, I have also put a power steer cooler in the front
Made up a steering column out of an IFS surf, beam axle surf and 70 series cruiser
My new (2nd hand) 120a alternator
Have a guess what has started now!
Relocated main fuse box and new frenched in box for extra fuses and relays
This is what is swallowing heaps of time, making all the clips etc to keep all the wiring and plumbing tidy and out of the way
I have chopped out a fair old chunk from here to allow for the snorkel to fit in between the inner and outer guard
Snorkel on and attached to the inner guard. I didn't want the snorkel attached to the A pillar so I can get the front clip off in one piece, complete with air filter.
And with outer guard on. I reckon it looks way better than having a fark off ugly pipe hanging on the outside
haydgq
Post by haydgq »
Thats some nice work you are doing, esp the wiring job and location of the fuses and relays etc, awesome so keep up the good work and Pics :)
H2OLOVA
Post by H2OLOVA »
Been busy aye bloody showoff :wink: Work can't have picked up that much :lol: :lol: :lol: :lol: :lol: Looking pretty sharp i have to say (for a hilux :P )
Petemcc
Post by Petemcc »
Looking wicked! I take it you are using the standard trans from behind the 304? If so have you figured out any way to manually control the shifting? I have one in my vp and am keen to try set it up so i can lock it in 2nd and not have it change into first when towing round windy bits and up hills etc.
Pete
