Twin battery setup in a hilux
Rypuppy
Post by Rypuppy »
I've just bought myself an LN107 hilux, and I'm after some info on the battery setup. Its got the factory twin battery setup, does anyone know how they are wired up? Like are they wired in parallel with a relay in between, so that you can run accessories and the like and only one battery goes flat and when you want to start the engine it will still start? And help would be appreciated.
Cheers Ryan
Sawdoc
Re: Twin battery setup in a hilux
Post by Sawdoc »
I have a LN107 as well with the twin set up, not sure of the wiring type but have used this set up with 12 volt halagen lights in the tent for a couple of nights on several accasions with no side effects. i was told that in Japan this is known as an outdoor!!! pack to run accessorys (spelling?) from without effecting the starting battery. To date i have had no problems.
Cheers Doc
91 HZJ73 Cruiser, 4.2 non turbo,33 x 12.5 kl71's,UHF radio, snorkle, diff breathers, Factory winch, Awesome club truck.
hosehustler
Post by hosehustler »
Usually just 12V set up wired together + to + , - to - with no relays or anything flash, simple set up think of it as one big battery cut in half, some surfs have the same twin battery set up, all it does it allow more battery storage space for accessories but they'll both go flat together and charge up together.
I hate signatures
tallsam66
Post by tallsam66 »
Its my belief they are referred to as a W
Eg KZN130W....meaning Winter ....supposed to be for the north of japan where they get snow etc & to make them easier to start in the cold
Rypuppy
Post by Rypuppy »
So it should be a simple job then to put a relay in between the two to isolate one battery when the key is off then? I'm looking at running an inverter off one battery while camping.
hosehustler
Rypuppy wrote:So it should be a simple job then to put a relay in between the two to isolate one battery when the key is off then? I'm looking at running an inverter off one battery while camping.
yep
I hate signatures
Steve_t647
Post by Steve_t647 »
We had this sort of thing setup in dads boat, but with a simple relay it ate the second battery all the time, we ended up installing the smart relay so the start battery charges then isolates itself and the second battery is then charged.
there was something about the battery not charging correctly when in parallel, this was on a boat tho.
hosehustler
Steve_t647 wrote:We had this sort of thing setup in dads boat, but with a simple relay it ate the second battery all the time, we ended up installing the smart relay so the start battery charges then isolates itself and the second battery is then charged.
Hi Steve I don't know if you've read this post from Bill Walker before but when I said it's easy here's what I meant
http://www.offroadexpress.co.nz/Forums/ ... +batteries :mrgreen:
Tim
I hate signatures
tallsam66
Post by tallsam66 »
Might pay to check it will start ok on just the one battery ...you may have to buy a bigger starting battery if it wont.
mudbugga
Post by mudbugga »
tallsam66 wrote:Its my belief they are referred to as a W
Close..... W means wide body spec.
Rypuppy
Post by Rypuppy »
I've got two 700cca batteries to go in, are they heavy duty enough? Or would it be wiser to use only one of them and have a deep cycle battery as my aux battery?
chevrolux
Post by chevrolux »
700cca should be pretty awesome! Im going to do the same but iv got 650cca. Cos im a lazy prick I bough one of these off tardme... http://www.trademe.co.nz/Browse/Listing.aspx?id=260581845
Pretty sweet kit but is pretty expensive.
Return to “Toyota”
