Trailing 4WD Transmissions???????
mudbugga
Post by mudbugga »
I might have missed something along the way so forgive me please, but ....... :oops:
I was reading some of the specs of a trials truck and saw they are using a frontwheel drive auto transmisson in a hybrid setup.
How are they doing this?
Why are they doing it this way?
Pedro
Re: Trailing 4WD Transmissions???????
Post by Pedro »
mudbugga wrote:I might have missed something along the way so forgive me please, but ....... :oops:
The front wheel drive auto is adapted to the back of a engine, V6 V8 or anything you like, the auto is usually in adaptions, made into a full manual auto, meaning pick a gear and it will stay there regardless of what the throttle is doing,
why?, you get a very short g/box arrangement, the diff turns into a transfer case, the diff is pulled out and welded solid in the g/box,then drive shafts run from where the axles used to be to the diffs, you can get the diff ratios to about 4:1
generally lighter than a g/box transfer case arrangement, definitely one hell of alot shorter, meaning the motor can go back further in the truck to give better balance front to rear.
disadvantage, top speed is really limited mine is good for a guess around 60-70klm per hr, that in overdrive at max revs,
advantage, makes the vehicle go like shit of a shovel, very quick throttle response, loads of low down torque, shorter, stronger?
Pedro
mudbugga
Post by mudbugga »
Cheers Pedro.
Are you using custom driveshafts incorporating the CV's or something else?
I'd be interested in looking at some photos if anyone has some.
Pedro
Post by Pedro »
mudbugga wrote:Cheers Pedro.
i made adaptor plates bolted the the inner CV bolt ring, that then adapts to the hilux drive shaft flange, there is a draw bolt thru the entire assembly to keep the stubs in,
Where are you
mudbugga
Post by mudbugga »
Cheers Pedro, I'm in Christchurch.
Just really interested how it is done etc
Pedro
Post by Pedro »
mudbugga wrote:Cheers Pedro, I'm in Christchurch.
not the best photo but the only one i appear to have
mudbugga
Post by mudbugga »
Great!!
Yes very compact setup!
Does it handle the power and load it gets put through OK?
mudbugga
Post by mudbugga »
I can know see how easy it would be to mount the alternator off the rear as well.
Good stuff!!
Pedro
Post by Pedro »
mudbugga wrote:Great!!
yup
3.8 supercharged v6, 4.1 diffs and 35" tyres, no issue so far
pedro
Pedro
Post by Pedro »
mudbugga wrote:I can know see how easy it would be to mount the alternator off the rear as well.
Good stuff!!
not so easy, belt replacement would require pulling g/box off motor to get belt around pulley
motorhead
Canadian
Post by motorhead »
Have a Rover Vitesse with 5spd auto, 2.7 Honda/Rover great power through the entire RMP range, extra LWB Paj, convert to SAS, sounds like a plan. :mrgreen: :mrgreen:
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
Return to “Tool Shed”
