Started to do timing belts on my Mitsy and found out I was supplied the wrong parts.....
OK, so then had to drop the missus off to work so I could use her zooki to swap the wrong bits etc.....then that pos starts to miss like a buggery.....
Just another job to look at....
So I go to the place I got the parts from, found out they are closed till Tuesday....
I give up.... time to start drinking - again
Hope everyone else has better luck!
