1kzte surging
bigstu
1kzte surging
Post by bigstu »
Hi just recently got a kzn130 surf the engine has started surging at 100kmh and sometimes wwhen taking off from idle, does anyone have any ideas on what itcould be and how to fix it ive just had a career change and have bugger all coin now to take to a garage.
Thanks Stu
andrew007
Re: 1kzte surging
Post by andrew007 »
check fuel filter,maybe blocked with diesil bug,etc.also fuel tank breather not blocked :D
bigstu
Re: 1kzte surging
Post by bigstu »
Hi it had new diesel filter put on just before i got it so shouldnt be that ill check the breather etc
chrome
Re: 1kzte surging
Post by chrome »
i dont want to bring bad news but mine surged when you take off when the dual mass flywheel crapped out, i hope its not :( mine was in a prado tho)
DIRTY OLD HILUX
022 519 7700
UBZ
Re: 1kzte surging
Post by UBZ »
mine did a similar thing when the dual mass gave out as well.
If the flywheel is leaking oil , its stuffed.
How many km's has it done?
bigstu
Re: 1kzte surging
Post by bigstu »
Its an auto should just have a flex plate shouldnt it? its done 130000ks
Pajmad
Re: 1kzte surging
Post by Pajmad »
Probably the efi diesel pump.
1992 lwb Pajero 2.3tdi 15psi Keeping It Real
chrome
Re: 1kzte surging
Post by chrome »
not sure aye, mine was a manual, its something to look at tho, cross ya fingers
DIRTY OLD HILUX
022 519 7700
UBZ
Re: 1kzte surging
Post by UBZ »
have you checked / changed the Transmission fluid , flushed it out?
has engine check light come on ?
Karl0z
Re: 1kzte surging
Post by Karl0z »
hey try checking your throttle bodies, myn was surging too and i had a gunked up 2ndary throttle butterfly cleaned it up and ran sweet after that, also check the acuator hose that runs into the 2nd butterfly isnt leaking air/vac.
bigstu
Re: 1kzte surging
Post by bigstu »
All sorted now got it fix this week as it got real bad turned out being a temp sensor and a injection resistor/ sensor thingie
