Got the P plate YUUUK
Went on a mission to north-west Auckland on Thursday night and collected my turbo
But its here and I'm happy with the fact I spent more for something brand new and exactly what i was after as opposed to something cheaper, older and compromised.
I bought a red 38mm wastegate. Its a tial copy which was literally 1/3rd the price of genuine. Although many people (especially in the sports car scene) will shudder at the thought of using non-genuine parts; I've had much experience with chinese made stuff and in general there have been few problems. The up side is that if a part does fail (spring, diaphragm) genuine high quality parts DO fit in as replacements.
Also purchased a cheap ball and spring boost controller. The price was incredible off trademe and they are so simple you really cannot go wrong. Ball and spring MBC's work as a pressure regulator and give you a much more responsive turbo system compared to if you used a bleed type valve.
On monday at lunchtime the truck goes into Cartune for an oil change and tune up. The engine will get a good looking at as well as all the tappets adjusted to remove the clattering.
The owner, Kelvin, mentioned that the rockers may be thrashed out and need either cleaning up or replacement which was reassuring as I'd heard of this issue before from other specialists. Its nice knowing that the mechanic in charge knows about any issues before they open things up
I figured it was time i had things looked at as the chattering was only getting worse
So.... all this means that over the next few weeks I'm in the perfect position to start building my own exhaust manifold. I considered using an off the shelf cast unit but availability and initial cost + shipping were certainly prohibitive.
So.. This weeks questions are as follows:
-Who in nz/Aus can help with a Turbo cam for the TD42?
-Are there any pre-formed collectors available for purchase to take 6 pipes?
