killing hubs
Nick555
killing hubs
Post by Nick555 »
Hi
At the moment my 80 series vx is destroying it right front hub. Normally after a trip offroad. has done it 3-4 times now over 6 months.
Does have 3" sus lift would this be cause or is it something else?
Nick
andrew007
Re: killing hubs
Post by andrew007 »
wot part of the hub is it destroying?is the spline on the end of the cv stuffed & stripping the hub? :roll:
albundy
Rolly Polly
Re: killing hubs
Post by albundy »
Won't be the lift. How much grease is packed in there, this may be the issue?
Al
Steve_t647
Re: killing hubs
Post by Steve_t647 »
Do you have a photo? i would suspect the splines on the end of the CV are worn, jack the wheel up and remove the grease cap, roll the wheel forward and back to see how much movement you have at the hub.
it does not take a lot and usually if the splines are worn there is a clunk in the drive line, this is one of the reasons the Aussies went and developed a part time kit, the other was fuel economy.
Return to “Toyota”
