HELP PLEASE
HELP PLEASE
hey dudes it seems the white whale has spat the clutch on me and i need a bit of help removing it Tuesday evening I will then get new clutch kit have the flywheel ground and hope to put it back in Friday evening
i need to get it into work to mount the pto on saturday/sunday
workshop is Hebden Crescent,off motorway belmont end turn right Ajustable Shelving drive on right DOWN through gate and your there Will be there at 6pm Tuesday
thanks in advance
taz01
thanks in advance
taz01
WARNING:
Re: HELP PLEASE
Taz, I'll see what I can do. Still need to finish my head gasket
So can't make any promises
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
?????NEXT?????
06 306 6098
021 02759048
Re: HELP PLEASE
So it's help you on Saturday till 8:30 pm, now it's help you until god only knows what time.. what next??
See you there fella....
Re: HELP PLEASE
we are now going with plan B .............remove the body ....fix the clutch chuck silver cab with on..............so bolo if ya read this theres my update.................
WARNING:
- tara13
Re: HELP PLEASE
See you boys at 6
- Beer_Cruiser
Re: HELP PLEASE
You supplying the beer?
Green bottles please....
Re: HELP PLEASE
I'll come to help out. Keen to see how this operation shapes up
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
Re: HELP PLEASE
Many thanks to those who turned up ......the ole beastie now weighs about a ton less with the body and the mud gone.
Thursday shove the box back on connect pto shafts
and Friday a few hands will be needed here put the silver body on wire up engine and fire up....
again thanks to all tonight...........
WARNING:
Re: HELP PLEASE
taz01 wrote:we are now going with plan B .............remove the body ....fix the clutch chuck silver cab with on..............so bolo if ya read this theres my update.................
Churr
Re: HELP PLEASE
Tonights Effort.................
Ground flywheel on....
New clutch kit on....
exhaust fell onto the disc grinder.........oops
front bar fell off so ready to fit pto
shocks needed extra rubbers
so plan tommorrow is fit the gearbox and mount the cab with my little lift blocks
WARNING:
Re: HELP PLEASE
The old body removed
Taz thinking about putting the body back on... or not?
The first WOF check list... shall I get a WOF or not.... nnnnaaaa don't need one
Let the cleaning begin....
Thats better, now we can start the rebuild...
Re: HELP PLEASE
taz01 wrote:Tonights Effort.................
Dude why didint you say you working on truck tonite.......would of helped you....but got the 70 together....
Don't have 4wd.
Re: HELP PLEASE
Tonights Effort:
Gearbox bolted on
Pto shaft on
Cab on
fark its a different beastie now................pics please reece....
Thanks to guys that helped.....
Tomorrow is connect wires
bleed clutch
bleed brakes
and start her up..................
Gearbox bolted on
Pto shaft on
Cab on
bleed clutch
bleed brakes
WARNING:
Re: HELP PLEASE
New truck now fella!
Sit's rather high though on those 37's!
Looking good though, will be there tonight I think....
Re: HELP PLEASE
