hey all
I was just wanting some advice for replacing the rear pinion seal. It is leaking really bad. Heaps of people reckon to replace the crush sleeve or something, some say don't worry about it. Is this a hard job?
rear landcruiser(bj42) pinion seal
Re: rear landcruiser(bj42) pinion seal
pinion seal is easy(ish)
if your going to do the crush tube you'll need to remove diff head, so mite as well do the carrier and pinion bearings as well...$$$$$$$$
