Hi
I want to mount tow hooks to the front and rear of my pajero but I don't know where I should put them or how to mount them correctly. Any photos would be great.
It is a 89 SWB Pajero leaf sprung rear.
Thanks
Rated Tow Hooks
- nick.falconer
- Driver/Navigator
Rated Tow Hooks
92 Surf
Re: Rated Tow Hooks
Will post pics Tuesday. Mounted front left just behind bumper, used one factory 12mm hole in frame and drilled a second. For the rear also used a factory hole and drilled the other on the left side. Used a metal cutting dic on my angle grinder to remove a bit of the bottom of the bumper and remove sharp cutting edges. Hope this helps.
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
?????NEXT?????
06 306 6098
021 02759048
Re: Rated Tow Hooks
motorhead wrote:Will post pics Tuesday. Mounted front left just behind bumper, used one factory 12mm hole in frame and drilled a second. For the rear also used a factory hole and drilled the other on the left side. Used a metal cutting dic on my angle grinder to remove a bit of the bottom of the bumper and remove sharp cutting edges. Hope this helps.
as the man said but add a plate on the inside of the chassie to help spread the weight
Re: Rated Tow Hooks
2 views of front hook. Rear M12 grade 8.8 bolt goes through factory crush sleve, front bolt through doubled frame rail using large thick washer.
Rear hook using one factory hole and other drilled. Slight trimming of bumper to remove all sharp edges
Hope this helps
Hope this helps
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
?????NEXT?????
06 306 6098
021 02759048
- nick.falconer
- Driver/Navigator
Re: Rated Tow Hooks
Thanks for the photos. I will probably be able to do the front one with some cutting of the bash plate, but the rear one I will have to find somewhere else as that is where the spring attaches to the chassis.
I was thinking for the rear I will have to go to a tow bar shop and get a bracket made up and replace my current tow bar and swap between the two depending on what needs doing.
92 Surf
