Hi there need a new clutch master for a kzj78 or if someone knows of another model that has same. having problems locating one. been to BNT, repco, toyota( 6 weeks $300) , autostop ( out of stock) any ideas/help
thanks
need clutch master cylinder kzj78
- IcedJohnno
- Trailer Trash
Re: need clutch master cylinder kzj78
Get it reco-ed. They will bore it out and insert a stainless or bronze line. No more corrosion problems, especially if the truck sits for a while....
3 places that do this in Chch, I am sure you will find somebody in Jafaland
If nobody else knows, Ollie at Sterling Brake definitely will.
I need to do this to my brake master Cyl soon.
I did reco it then found that there is slight damage to the actual cylinder, leak is so slow it takes about 24 hours for enough air to stop clutch working, took 3 bleeds and alot of swearing before I found it. not much fluid gets out the leak it's so small.
So need a whole new one.
- IcedJohnno
- Trailer Trash
Did you just hone the bore or was it re-machined?
If properly re conditioned via remachining and a new sleeve correctly installed, then you should have no leaks.
If this was done, and by a professional company and you still have an issue, then you have every right to ask them to make your cylinder good. In whatever shape that may take, i.e. them re-reconditioning it, or them replacing it.
I can't see why it would need replacing though as the remachining process, if done properly, generally makes for a better cylinder than new.
My one has the dampner on the bottom, also where the booster goes if it has one, where the two parts attach is where the leak is, remachine will not change this problem. Just need a new one
are they the same as a kzn 185 if so i have one here cant be to far of is it a 1kzte
thanks for that got one today it's from a kzn165 I think. works fine. Now need to do the clutch as well. going to have to change to solid flywheel and HD clutch, My current one has only done 6 months and thrust bearing on way out. will try to get a new one on warranty.
duel mass flywheel on way out big time.
that wont be cheap just done the clutch in my super custom & it was a standard clutch with a recessed flywheel & just the clutch kit was $720.00 by the time i had the flywheel skimmed it all adds up i think i spent 1k
