Heavy duty clutch worth it?
brakes-shocks-lockers-etc
mudmike
Post by mudmike »
Hi guys, doing a solid flywheel swap from stuffed duell mass on my kzj78 with 1kz. Do you think a HD clutch is worth the extra $350? it's just a heavier cover. opinions would be good.
thanks
Re: Heavy duty clutch worth it?
can they tell you the difference in the pressure plate pressures between a std clutch and a hd one?
If you've got big tyres and diff locks you'd need as much clutch as you can get?
mudmike
Post by mudmike »
they said 50% over standard, my truck twin lockers and 35" tyres
mudmike wrote:they said 50% over standard, my truck twin lockers and 35" tyres
yeah mate I'd go for it if its that much stronger
curly12
Post by curly12 »
Na, don't bother if you enjoy replacing standard ones every two years :mrgreen: :mrgreen:
Well worth the money otherwise
IcedJohnno
Trailer Trash
Post by IcedJohnno »
Ive got twin lockers but choose only 31's cos of the big chains I run. I have had no probs (touches wood)
However I would like Sadam choose the HD option.
Whilst you are at it, spigot bearing, release bearing and what's the front oil seal like?
At 200k due to the previous Asian who did not know the flywheel was U/S, my syncros are shagged. What are yours like?
Have a look at the output flanges/shafts on the TF box too. Mine are now all wobbly :roll:
mudmike
Post by mudmike »
gearbox and transfer have been rebuilt, didn't do flywheel on bad advise. Also I like pulling it out so much :lol:
Looks like it will be the HD one, no one tell the wife there was a cheaper option :D
Heath
Post by Heath »
"Quality remains when all memories of cost have faded!"
